try reverting to vga mode http://www.playtool.com/pages/safemode/safemode.html
tap f8 a couple of times after bios shows, then select vga mode in the list
if that works then you can change to a different resolution in display
Hook a spare monitor to the video output on the back of the laptop, if okay! the LCD screen is bad and must be replaced, also! check the video cable from the motherboard to the screen, on rare occasions it comes loose. If both screens show the same symptoms, it is the video graphics card that is part of the motherboard.
Try to plug in an external display (take the one of your desktop PC if you have). If it works on an external as normal then the problem is physical and it has to do only with the screen (new screen or invertor, or screen cable). If the same problem happens on the external monitor, do not touch the screen part. the problem then must be either video card or motherboard. I suggest try to do this trick with the external monitor to find the problem for youself and then use your warranty and bring it to the shop to have it repaired.
hi, if ur screen turns white, it could be any problem starting from ur LCD to motherboard or as u said a virus. to assist u in a right way i need to know what exactly is happening between that short duration between pressing the button and white screen. most importantly is anything else comming up on the screen before the white screen.
cheers
the last time my friend's old cp would not start and showed a white screen, it was nothing else than changing the power box that had gone dead from overheating - the fan was stuck hard since weeks!
