Question about Xerox DocuColor 12 Printer
How do i solve system failure error 10-377 - Xerox DocuColor 12 Printer
yescopier
  • 22 Answers
Intermittent 10-359 Heat Roll Control Thermistor and 10-368 Pressure Roll Thermistor Failure fault codes. The RAPs have been followed with no resolution. Thermistor resistance checks were good and the thermistors were replaced. Fuser module PJ 700 pins were not bent.
The inboard Plug 700A is mounted in a metal plate that was bent, not allowing Plug and Jack to mate properly causing intermittent failures. P 700B (PL 8.5) is mounted on the fuser, J 700A is mounted on the Rear of the processor.
Remove the inboard Plug 700A from the rear of the machine and the metal mounting plate. Ensure the plate and Plug are not bowed or bent, reform or repair as necessary. If unable to repair, order part # 913W2310.
Posted on Feb 15, 2011
Solve the plroblem in di 620
The 13xx - printer engine malfunctions
13F0 -400 dpi SOS sensor detection failure.
13F1 -600 dpi SOS detection failure.
13F2-universal tray adjustment failure maximum.
13F3-universal tray adjustment failure minimum
13F4-optical system out of adjustment
Dec 15, 2013 | Minolta DiALTA Di520 Laser Printer
Tip
How to Fix Computer
If you face any problem with your computer system you can either fix ityourself or get it fixed by a computer professional. You need to fixall the hardware and software related errors for proper functioning ofyour computer.
Hardware and software errors
The common problems faced with the computer hardware includes the harddrive failure, power supply failure, motherboard failure, CPU failure,video card failure, USB device failure, and many others. The commonproblem with software includes - programs refuses to install, programdoesn’t load or takes more time to load, software functioningimproperly, operating system failure, incompatible device drivers, andother related issues.
There can be a wide range of problems which might occur in your PC dueto several unseen and even unknown issues like your computer does notturn on, you see a disk error message when you log on to your systemand many others. If you are a Windows user then you can find the helpfor most of the common hardware and software related errors on yourcomputer itself. Microsoft Windows offers a help section mentioningsolution to some of the most common hardware and software relatedissues.
Windows "Help and Support" center
You can have a quick access to Windows help and support centre inWindows XP systems by clicking on the "Start" button followed byclicking on the "Help and Support" center. Similarly, you can alsoaccess the "Help and Support" centre in other versions of Windowsoperating system. The help center carries a database of the most commonproblems and solutions. After opening the help center you can type thesearch term in the search box to find the solution. It will display alist of results on the basis of the search query. It is yourresponsibility to find the best solution for the problem you are facing.
In case of system failure you can carry out some of these troubleshooting steps to solve this issue:
  • Check if your PC is plugged into a power source and it is switched on.
  • Reboot your PC to check if the problem still persists.
  • Restore your system to an earlier state.
  • Scan your PC hard drive for any errors.
  • Check for any memory problem.
  • Check for any device driver related issue.
  • Reinstall the operating system.
Finally if you are still unable to solve the issues then don’t proceedon making some irrecoverable changes, you can avail online help from atech support company who can solve your problems through remotecomputer repair service
on Feb 02, 2010 | Computers & Internet
SYSTEM ERROR E100 on canon IR1018
Main cause The laser driver/BD PCB is faulty (laser activation failure, BD
detection fault). The DC controller PCB is faulty. The image
processor PCB is faultly.
or drum is faulty.
Oct 20, 2012 | Canon IR1018J Black and White Copier
Ink System Failure Error Oxc18a0201
Read this, it should help you:
http://www.fixyourownprinter.com/forums/printer/50063
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Acer travelmate 290 error
Use another Bootable Disk Operating System to see it as may be the same problem you have. I think it's your Installer Disk have a problem.
From this problem it's windows system failure to show display appearance normally.
At least you try just one installing another Bootable Disk.
Sep 23, 2009 | Acer TravelMate 290 Notebook
Error 151 System Board Failure. Tech manual says Real Time Clock failure, but doesn't suggest how to remedy.
Hello
I read about your problem, and apparently this occures when the battery on your motherboard is running low on voltage, in other words the battery is low. This error code explaines a weak battery warning your circuit.
Just take out the battery and replace it with a new one and your problem should be solved.
I really hope this can help you.
Best regards
Sep 14, 2009 | IBM PC 300PL (DTIBMP3550R) Barebone
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
How to solve hd audio failure error
reinstall the hd audio drivers .. and look for any errors in the device manager..
Jun 23, 2009 | Microsoft Windows XP Professional With...
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
System file has an error.
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
May 13, 2007 | iRiver PMP-140 Digital Media Player
Xerox DocuColor 12 Printer Logo
326 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
