Question about Nokia 3230
My nokia 3230 do not detect my sim card & do not show network also.Bu it does not show that insert sim..How to repair it??
smozhe
    President:
  • 2,360 Answers
You can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.onlinegsmunlock.com/nokia-3230/rs7wp9/
Posted on Jan 17, 2011
Angelbday27
    New Friend:
  • 18 Answers
If not detect the sim card means it locked to Network,call the service provider and get the code and unlock it....
Posted on Jun 10, 2011
All time demands SIM insert, has already made insert SIM.
It may be due to network lock,
you can unlock it and switch over to another network , you can get unlock codes here http://www.mobile-unlocker.com/nokia-3230/rs2wp9/
you need to specify the country and network provider
Jan 17, 2011 | Nokia 3230 Cellular Phone
My nokia 3230 desplays the words 'insert simcard'even if simcard is inserted
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.prounlocking.com/nokia-3230/rs8wp9/
Jan 10, 2011 | Nokia 3230
When i switch it on, my nokia 3230 keeps restarting and most of the times displays "insert sim" and "invalid sim". Please help me. Thanks. Paschal, Nigeria
it may be due to network lock, contact service provider , else you can get unlock codes here http://www.theunlockarena.com/
you need to specify the phone model and network provider
Oct 08, 2010 | Nokia 3230 Cellular Phone
Sir.. i m not able to send the messages ..once i get restart so only i can send the 10 or 15 messages but after that .. sending failed.. i have changed the network connections also but problem presists......
Check your setting of message center.the easy way, remove your sim card than switching on without sim card for a while (3 minutes is ok) than switcing off,insert sim card back than switcing on again.Good luck.
Jun 09, 2010 | Nokia 3230
I have nokia 3230 i do recieve sms but im unable to send sms
Turn off your phone, remove sim card then turn on without sim card.after a while turn off, then insert sim card again and turn it on.Good luck.
Apr 29, 2010 | Nokia 3230
I have a Nokia 3230 set & i dont get any sms. when my friends sends a sms to my mobile i cant get it & i cant send them too. please help me i have also formatted my mobile.
Tray to remove SIM card from phone.than turn it on without SIM for a while,switching off and insert SIM back than turn it on.Good luck.
Apr 01, 2010 | Nokia 3230
Help please! My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the...
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
Mar 29, 2010 | Nokia 3230 Cellular Phone
Repair nokia 3230 on line
Try updating the software using Nokia Software Updater
Be sure to make a backup using Nokia PC Suite so you don't lose any data.
Aug 31, 2009 | Cell Phones
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Nokia 3230 Logo
224 people viewed this question
Top Nokia Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
sandyp4ever
sandyp4ever
Level 1 Expert
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
