Question about Homelite Carburetor Trimmer Blower Mightylite Versatool
Plastic primer cap perished can a replacement be purchased
Posted by wesnfran on
Don Myers
  • 463 Answers
Hello wesandfran, yes, that is a very common machine and you may even find the part at places like Home Depot.
I hope this helps you,
Good luck my friend!
Posted on Jan 17, 2011
I have an airweight 38 does it hurt the gun to dry fire?
It won't HELP it, that's for sure. Go to a sporting goods store and purchase what's known as "Snap Caps" for your weapon's caliber. They're small plastic "ammo" that has a spring embedded where the primer/igniter would normally be located. When you dry-fire, the spring provides the proper resistance to the firing pin, preventing over-extension and premature wear/breakage of the pin. They're cheap, and since you have a wheel gun, you can load 'em once and shoot again and again and again. https://www.amazon.com/Tipton-Snap-Caps-Special-Magnum/dp/B0048KFHKQ/ref=sr_1_2?s=sporting-goods&ie=UTF8&qid=1491493949&sr=1-2&keywords=snap+caps+.38+special
Apr 06, 2017 | Air Tools & Compressors
Is the primer bulb replacable on 200 classic chainsaw.or do I have to buy a new gas cap.
Hi Shirley:
My apologies if I'm incorrect, but I've never seen a chainsaw that had the primer bulb connected to the gas cap.
So,,,,,
I'm hoping you're asking two questions at the same time.
1) Primer bulbs are replaceable but it's extremely rare that it is necessary
2) Gas caps are replaceable but only needs to be done if they are broken.
If you reply as a comment on this post I'll be able to respond to you.
Cheers.
Oct 14, 2015 | Homelite Garden
My briggs and stratton 158cc 500series push mower primer button melted from sun. how do i replace it?
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
May 09, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
Asked to repair a McCulloch wipper snipper model TM251SST+. Found fuel line inside tank perished as well as outside primer bulb. Replaced with new. The petrol does not pump up when primer bulb pressed. I...
the primer bulb has the valves in it ,check the in line fuel filter.take outlet off primerbulb,should pump thru from tank,thru the primerbulb
Jul 11, 2010 | Garden
How do you remove the primer bulb on a model 10a902 Briggs and Stratton mower engine?
Look at the outside of the plastic housing where the primer bulb is inserted, you will see an open area where there are 2 tabs, one on each side, using a small screwdriver, push these tabs inward to release them and slide the whole thing out of the hole including the primer bulb. The new primer bulb normally comes with a new mounting ring if you purchase it from a lawnmower dealer
Sep 27, 2009 | Briggs & Stratton Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Where is the oil filter located on the bmw 116i
right at the front in the middle below plastic housing. Has 1 large plastic cap on a metal lower casing, not metal bodied like old oil filters just has filter element. Also replace 'O' rings that should come with the new filter as the old will have squared off or become perished. I think you need a 27mm socket to undo the filer housing.
May 12, 2009 | 2005 BMW 1 Series
Needs carburator adjustment for poulan model # FL 26
Sure. (This will void your warranty and bypass smog requirements!) There is a red and a white limiter cap on the carburetor adjustment screws. Red= High speed / White = Low speed. Remove limiter caps. Turn both jets a 1/2 turn counter clockwise, Start, then fine tune. Use the low speed and idle screws to smooth out low to idle speed and the hi speed jet to tune the full throttle.
Apr 08, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My car has been running hot for the past few days, and my heat completely stopped working yesterday, i checked the antifreeze and it was bone dry, there is a huge puddle in my driveway. Where could it be...
Check the following while running the engine, with coolant topped up:
The plastic reservoir bottle could be cracked check for leaks.
One or more of the hose-clamps aren't sealing well enough.Re-tighten or replace.
The radiator cap seal is torn or broken this would be obvious by steam and/or sputtering water at cap level.Replace cap.
The radiator might have sprung a leak or rusted through.Repair or replace radiator.
The cooling hoses may have perished.Replace.
Check around the water pump as one of it's seals or bearings me be worn out.Repair or replace.
Hope that helps! Good luck!
Mar 10, 2009 | 1998 Ford Taurus
I need a fuel line and a primer fuel pump (plastic bubble) for my Ryobi 31cc trimmer plus. Any idea where I can get the parts?
You can order them directly through Ryobi and pay a small fortune or you can go to any small engine repair shop and purchase the fuel line by the foot. I believe your primer bulb can easily be replaced with what your local shop will have in stock. The parts from your local shop will probably out last the factory parts anyway.
Mar 08, 2009 | Garden
Homelite Carburetor  Trimmer Blower Mightylite Versatool Logo
70 people viewed this question
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
