Toshiba Satellite Laptop Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Toshiba Laptop computer is slightly bright and I would like to know how to dim it. Thank you.
Anonymous
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Jan 17, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
85
Questions
Helped
12089
Points
250
Its most likely a fn + some other key, look for a sun with an arrow by it dimmer light also extend battery life a little bit too.
Anonymous
Level 3:
Genius:
  • Master 1,570 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1570
Questions
0
Helped
385829
Points
4486
Hi there !
Just press the FN key + Dim key (Picture of shaded sun in your keyboard).
I hope it helps you.
2answers
Display screen appear dimmed
If it's a windows 10 laptop right click on the desktop and go to display setting and increase the brightness.
1helpful
Dark picture on monitor
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
1helpful
Screen is dimly light
If the screen light dim with battery power your laptop, well, this is how the laptop is designed for power saving, unfortunately.
The screen will be more bright when you connect with the AC power :-)
I have a toshiba 46WM48P rear projection Dimmed brightness
that sounds like a typican lamp going out.. (needs a lamp every 3000-6000 hours of viewing)
this is your lamp part number. if you have any questions about installing the lamp contact fixya chat
23311153X
1helpful
2answers
MY A100 LCD SCREEN IS VERY DIMM WHEN VIEWING DVD howto brighten
You can brighten or dim the LCD screen by pressing the Fn key plus another key with the a sun symbol eg the UP & DOWN arrow keys or one of the F3 to F12 keys - it varies depends upon the model of the laptop.
If you cannot vary the brightness of the LCD screen the you have a faulty backlight.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Toshiba Satellite laptop won't start
From Toshiba Manual:
"Over a period of time, and depending on the usage of the
computer, the brightness of the LCD Screen will
deteriorate. This is an intrinsic characteristic of LCD
technology.
Screen will dim when the computer is operated on
battery power and you may not be able to increase the
brightness of the screen.
Try pushing Screen contrast to Max when on AC charger connected.
Allow several hours charging battery with PC off.
If battery does not completle charge Or if older than 3 years CHANGE it.
1helpful
Toshiba equium A100-306
try function key for lcd it may be in presetaiton mode by mistake
or is lcd on / come on bright then go dim / dark just very dim if so your backlight is out replace lcd
Problem with Brightness and Dimness Adjustment
No. there isn't, unfortunately. You need to download the touchpad drivers (probably synaptics touchpad drivers). My recommendation would be to go to toshiba's website. Specifically, go here then find your model and download the touchpad driver: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
Display problem
Wiggle the power wire slightly. Sometimes if the connection is loose it may cause the computer to go from battery power to ac power.
If that doesn't work, could be a loose connection in screen or a part is failing. Would take to a local repair center to check out.
3helpful
I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107128&moid=1073769765&BV_SessionID=@@@@0579949615.1140817607@@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
