Question about Logitech X-530 5.1 Surround Sound Speakers&Subwoofer - 970114-0403 Computer Speakers
When I'm not playing anything on my puter that has sound, I have a bunch of static that comes through. Everything is hooked up right. How do I get the static to stop? Is it a driver issue? Or maybe a cord?
Posted by jamie_shoup on
Anonymous
    New Friend:
  • 85 Answers
Cord prolly or maby the "puter"s just how my little brother says it sound card is dead
Posted on Jan 17, 2011
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
I have a Static noise coming from the right channel of my mixer. I hear it coming out the right speaker as well as the right ear of my headphones (jack). How can I fix this?
That sounds like a bad connection but it can also indicate your mixer has a problem. If it occurs on all channels it is the mixer, if only one then the problem is in the input. Check your cables, they are a big culprut in problems like this.
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Box was working, tv now back to analog
Sounds like the converter didn't make it. The symptoms you describe sound like the converter was working and then died. You may want to bring it back to store were you got it.
Lights everything seems to be on, but no sound
make sure the speakers and everything are hooked up correctly and try to use the different functions if you have an aux cord use it with an mp3 player or ipod and see if it will play music if you've already done that well then i dont know what to tell ya
4helpful
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
1helpful
Why do i have static and then no sound ?
Hi...
You have a faulty reciever.
Take it back and get another.
No sense in going any further.
1helpful
Sound card freezes up
Buy enternal power supply for it.
9 Volts
1000mA
But mind that it should be psu with REGULATED output(steady 9Volts).
Audio static through DVD Recorder
I your TruTech T650-DR is geting real hot turn it off its over heating.
If thats the case then your not setup right. What ever is gonig on dont keep using it, its gonig to burn out. cheek to make shure you have every thing plug in right.
Top Logitech Audio Players & Recorders Experts
Marvin
Marvin
Muzahura Frank
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
