SOURCE: Olympus 1050 - lcd screen blank, gasket was loose.
It is possible that since water did get into somehow that it did some internal damage to the camera. I recommend that you call Olympus Customer Service and discuss the repair process with them. Their telephone number is 800-622-6372 option 2 and then option 3
SOURCE: Olympus mju850 - fine at night but hugely overexposed in daylight
it is ur luck if camera still works in indoor pics then only take indoor pics but the pics are not crisp and clear they need to be there will be dis colored and scratchy but u can try see which are better i think pics without flash with adequate light will be better one's
i am here to help u in this if u like
SOURCE: Downloading Pics to PC
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
SOURCE: when taking pic in sunlight - lcd screen is whited out!!
I think that's normal. I also have experienced the same always when the screen is exposed to sunlight. Try adjusting its brightness or use an anti-glare protection.
SOURCE: I cANNOT OPEN THE LENS OF MY CAMERA. OLYMPUS TOUGH
Apparently some problem in the inside of the camera with the lens assembly or something is disconnected. You can get in touch with the repairs of the Olympus company and see what repairs would cost. I am almost sure that the repair is going to be more than the camera is worth to you.
Many times dirt or dust can cause problems with the lens. Also this can be caused by internal problems which means repairs. In my experience with these small cameras, the lens repairs have been some of the hardest repairs to complete correctly. That is not saying that it cannot be done. If the lens is taken apart or removed, the camera should be re-calculated on a computer with the right software.
