Question about Kenmore 73952 Gas Dryer
Kenmore 73956 gas dryer will not stay on unless I hold the PUSH TO START button in. If I release the start button the dryer stops. If I hold the start button in, neither the heating element or the gas frame lights up. I then tried the test mentioned in the Tech sheet service notes founded under the control panel, to see if the timer dial moves, while holding the start button in, and the timer dial does not advance after 16 seconds when I tried it. I then tried the diagnostic test noted in the same Tech Sheet found with the dryer (dryer Door open, Signal End of Cycle switch set to-HIGH, Set Timer to TIME DRY or AUTO MOISTURE SENSING PLUS selection), then turn Fabric Care Temp switch from AIR FLUFF to ULTRA DELICATE three times within five seconds. If in test mode then you hear a beep sound then two beep sounds. I could not get it to beep or go into the test mode. Any help, Thanks, Gretchen
Posted by iflyfish on
fred gittner
    New Friend:
    Problem Solver:
  • 8 Answers
THE MOTOR STAYS RUNNING VIA A CENTRIFUGAL SWITCH IN IT. MY GUESS/SUGGESTION WOULD BE TO REPLACE THE MOTOR.
Posted on May 01, 2016
Mike Smith
  • Kenmore Master
  • 1,606 Answers
Raise the control panel and replace the electronic board ( 5" x 7" ) .Came across this same problem tuesday .
Posted on Jan 17, 2011
Kenmore Elite 11072972101 gas dryer will not stay on after I push the start button. What is wrong and how do I fix it.
If you HOLD the start button down and the drier heats and runs, then your problem is most likely a relay which is supposed to energize (close contacts), which "latches" the condition when you push the start button. The most likely cause of such a failure, is a fuse or a thermal cut out, which has prevented normal operation. For safety reasons, being a gas appliance, I would NOT ATTEMPT to fix this problem yourself, unless you have licenses to service such equipment!
Apr 17, 2017 | Kenmore Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Dryer will not stay running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Kenmore 63942 Dryer
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer 73956
sounds like motor switch
Feb 09, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore gas dryer timer? problem
Sounds like your centrifugal switch on your drive motor may be defective. The switch is supposed to "latch" (or stay closed) when the drive motor begins to spin. That...or, you may have a defective start switch. Please post back with your COMPLETE model number so I can determine how your dryer is configured as all dryers are not alike. I need to make sure.
Oct 26, 2008 | Kenmore 73932 Gas Dryer
Kenmore 73952 Gas Dryer Logo
258 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
