Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Hi,,My weiser powerbolt elec deadbolt has been working great for the last 7-8 months without a glitch,,,then 1 day started beeping like crazy,,,and when yolu press the #'s on the keypad,,they do not respond anymore,,,,I thought maybe humidity got to it so we used a blowdryer to try and dry it out,,,, Pls note we live up in Northern Canada so maybe cold is getting to it,,,,, Any input would be appreciated Cheers,,
  • Jack Tichener
    Jack Tichener Oct 12, 2017
    I've been having the same exact problem over here in Washington. I'm not sure if the rain is playing a part in the thing getting jammed or not but nothing I try seems to be working. If you find out an answer let me know!http://dupagesecuritysolutions.com/resid...
kbsangster
    New Friend:
I have the same problem in northern canada... did you find a fix yet
Posted on Jul 23, 2011
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Mar 31, 2014 | Weiser Lock POWERBOLT ELEC DEADBOLT
My deadbolt will not operate either manually or electrical without the key inserted
Yours is an unusual problem--one that I'm not familiar with. You did not specify whether you have a Weiser Powerbolt or Kwikset Powerbolt--(both are subsidiaries of Black & Decker).
So I suggest that you contact the appropriate Customer Service department and have a phone conversation with them about your problem.
For Kwikset, call 1-800-327-5625
For Weiser, call 1-800-677-5625
Mon-Sat 7:30-4:00 Pacific Standard Time.
Amazingly enough, they have exactly the same California address!
Also bear in mind that they both have a lifetime warranty against mechanical malfunctions and finish problems with their lock, but only a one-year warranty for the internal electronics (circuit boards). The electronics can be expensive enough to make a guy consider buying another brand of lock rather than rebuilding this one--I've answered more Powerbolt problems than for any other model of lock.
Good luck! Let me know what they do for you.
Dec 10, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
No sign of life at all. No beeps, no motor twitches, nothing. Up to now worked fine. It is not just the batteries.
Here is a link to troubleshooting your powerbolt lock. You will find the problem problem of beeping (or no beeping) addressed here:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
There is a link at the top of this page for Customer Support from Weiser.
Mar 14, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Touch pad does not work on weiser lock powerbolt. Batteries are new and beep when installed. Checked power board and is installed properly.
I found this Frequently Asked Questions sheet for the Powerbolt 1000:
I hope this helps.
Feb 23, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Changed the batteries but the Weiser keypad lock keeps beeping
Mine did that too for a month. Make sure all the batteries are new alkaline batteries of the same brand, and remove them for a few minutes (if already installed) and replace them in the unit. I reset my code as well afterword. Did the trick for me.
Aug 23, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
Jul 09, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Changed battery and lost program cant find manual need reprogram 4 number code
changed the battery and lost the manual, put my code in and it worked , latter it started to beep and now it doesn't work... respond at all ....help thanks
Apr 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
502 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
