Question about Vtech Digital Cordless Telephone VT-2568
I unplugged vtech tel to move to another location-now i have CL flashing and none of the phones have dial tone-how do i fix-thank you very much for your help
Posted by rbabiesx4 on
Chester Sohoski
  • 264 Answers
The main unit with the answering machine needs to be plugged into and outlet and also plugged into a working phone jack. The other units just plug into an outlet and speak to the main unit wirelessly. Make sure the main unit is plugged into a phone jack.
Posted on Jan 17, 2011
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Speed dial help
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
Dec 22, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Volume in earpiece barely audible, even though it is on Max.
best take em back to the shop as they are faulty..Tell em ya want a refund and go to Walmart and get yourself a uniden 3 pack cordless phone for $35 on sale.
Feb 04, 2018 | Vtech T2435 Dual Handset Cordless Phone
I can't dial out from my handsets
Here is something to try:
Disconnect or unplug the power supply (the small black box that is plugged into the wall outlet) wait for 30 seconds and then plug it in again. Sometimes the power supply needs to reset itself. It worked for me.
Thanks,
monotary
Nov 06, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Diigital answering machine and 3 portable phones
Here is the link for the manual; http://www.vtechphones.com/docMgt/public/art/20411/ip5850-man.pdf Page 23 - flashing CL means you need to set the clock. All explained there I think Hope this helps :)
Mar 05, 2007 | Vtech IP5850 Answering Machine
Vtech Digital Cordless Telephone VT-2568 Logo
127 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Ekse
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
