Re: I lost the combination to my luggage lock (brand:...
The only way to find the combo is to progress the combo wheels -- start at 000 and then 001,002,003,004,005,006 etc.. ( trying the latch at every number ). it should take you about 15 to 25 minutes to go through all the combos and get the right one.
Yoong queen,
You can able to open this number lock, but you show more patience,
put the lock number to 000 or 0000, then start with 001,002,,,upto 999 or 9999 if it is fourth digit. Each time you every digit give a slight pressure to the lever,,it will open with the correct number and open with that number you forget.
with regards
jaijith
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Try all the combinations. To save wear on your fingers, use a small screwdriver to dial the numbers. Try to open it after changing each digit. You can try all 1000 combinations in about twice the time it takes you to count to 1000 out loud, but unless you chose a combinations like 998, you will probably open it long before that time.
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock.
With the Combination
Step 1
Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
Step 2
Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
Step 3
Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination
Step 1
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2
Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3
Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination
Step 1
Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Step 2
Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Step 3
Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Step 4
Roll the dials until you have your new combination.
Step 5
Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals! www.alibaba.com$0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now! www.hostgator.com/1PennyRooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now! www.airconditionings.cnDownload Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now! www.facebook.comby Taboola Sponsored Links Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft RecipesSee Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
Do not open a lock that does not belong to you. It is against the law.
ABOUT THE AUTHOR
Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
