Some people use vinegar and water and run a hot wash with the unit empty i have found that when cleaning out any smell in a washer whether it be stagnant water smells or mold the one thing that works the best is a product they sell at home depot called AFFRESH it comes in two types one for the front load washer and another for dishwashers simply just add one tablet to your hottest wash without any clothes for heavy mold sometimes il run it twice with two tablets separately it sells for about 8.99 per package and is a life saver of all front loaders if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation this way I can keep helping people who have similar situations with there appliances Thanks again Rick
SOURCE: cleaning a front load washer for mold and mmildew
What's the question?
Use a mild bleach
heres the solution from washing machine manuals, dont know why fuses and powerre included in this...
odor in washer
• Water supply taps are not
open fully.
• Water line hoses are kinked,
pinched, or bent.
• Water inlet filters are clogged.
• Water pressure to tap or
house is too low.
• Power cord is not properly
plugged in.
• House fuse is blown, circuit
breaker has tripped, or power
outage has occurred.
• The door is not closed
properly.
• Incorrect or too much
detergent has been used.
• Inside of tub not cleaned
properly.
• Make sure that the water taps are open fully.
• Make sure the hoses are not kinked or pinched. Be
careful when moving the washer.
• Clean the inlet filters. See the Care and Cleaning
section.
• Check another faucet in the house to make sure that
household water pressure is adequate.
• Make sure that the plug is plugged securely into a
grounded, 3-prong, 120-VAC, 60-Hz. outlet.
• Reset circuit breaker or replace fuse. Do not increase
fuse capacity. If the problem is a circuit overload,
have it corrected by a qualified electrician.
• Make sure that the door is closed properly and press
the START/PAUSE button. After starting a cycle, it
may take a few moments before the drum begins to
turn or spin. The washer will not spin unless the door
is locked (DOOR LOCK will appear in the display).
• If the door is closed and locked and the open door
error message is displayed, call for service.
• Use only HE (High-Efficiency) detergent in accordance with the
manufacturer’s instructions.
• Run the TUB CLEAN cycle regularly. Be sure to wipe around and
under the door seal frequently.
• Clean around door seal/glass to prevent odor or mildew:
1. wipe dry the door seal/glass and the door opening area
2. wipe around the inner drum/door seal and the lower door seal
SOURCE: RUBBER LINER COLLECTING MOLD
I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
Take out the inserts and rinse them and the drawer thoroughly.
Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
