NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
Posted on Jan 16, 2011
I NEED TO BUY A CHARGER FOR MY GLOW BUOY FLOATING POOL LIGHT,,, RAY VELAZQUEZ- [email protected]
2 Related Answers
Anonymous
  • 640 Answers
  • Posted on Jun 16, 2010
SOURCE: my glow bouy won't hold a charge.
According to the owner's manual that I have for this swimming pool light (troubleshooting section), a blinking red light is definately a charging issue. The manual recommends that you unplug and replug in the light several times. If the flashing continues, they recommend that the batteries need to be replaced. Unfortunately, you cannot replace the batteries yourself. They specifically state that you cannot open the housing yourself. If you did, you would risk electrocuting yourself AND void any warranties that you have. You will have to take it into the retailer that you got it from or an autorized pool supply/repair shop or replace the whole light.
Anonymous
  • 640 Answers
  • Posted on Jun 29, 2010
SOURCE: I need a new bulb for my glow buoy pool light!
The Glow Buoy swimming pool lights were designed so that the bulbs can only be replaced by a licensed pool supply store. If you open the light yourself, you will void any warrantly and risk breaking the unit. Becuase of this, they don't sell the exact bulbs that you need unless a pro is installing them.
I need to purchase/order a new plug in device for the glow buoy
You might want to check with backyardcity.com. I know that they sell an assortment of swimming pool lights. If they don't carry the charger, they can probably direct you to the manufacturer. If you have a number to the manufacturer, you might want to contact them directly. Also, a local pool store might carry them.
1helpful
I have lost the ac charger power cable, manual, and other accessories that came with the 92000 i purchased a few years ago during a recent move. Where can I order these items and other accessory items for...
I am not sure if they sell accessories, but I know that Backyardcitypools.com sells these kinds of swimming pool lights so they might be able to help you get what you are looking for or point you in the right direction. Hope you find what you are looking for!
I can not find my charger. Where can I order one.
I am not sure if they sell accessories or not, but you might want to check with backyardcitypools.com. I know that they sell these types of swimming pool lights so they might be able to get the charger for you or at least point you in the right direction. You might also want to contact the manufacturer. They might be able to give you more info.
Need to buy a new bulb for my Glowbuoy 92000
You might want to try backyardcitypools.com. I know that they sell these kinds of swimming pool lights. I don't know if they have replacement parts or not, but they might be able to point you in the right direction or get you a replacement if necessary.
1helpful
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
2helpful
I need a new bulb for my glow buoy pool light! how much and were thanks!!!
2helpful
Lost my charger too!
You can purchase a new charger for these swimming pool lights from the manufacturer or the retailer from which you purchased the product. They recommend that you do not use after market chargers not designed for this product. Their website is listed as www.cantar.com and the contact number listed on my warranty information is 800-448-2343
1helpful
The electrical plug for recharging is misplaced. can i purchase a replacement?
You should be able to purchase a replacement charger for this swimming pool light from the manufacturer or from the retailer that you purchased the light from. I would not recommend using an after market charger. You can contact the manufaturer via their website www.cantar.com or call them at 1-800-448-2343. This is the info listed on my warranty.
1helpful
2answers
My glow bouy won't hold a charge.
my glow bouy just keeps flashing on and off after recharge, had it about 2 years hardly been used
Top NRS Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
