Question about Whirlpool Duet GHW9150P Front Load Washer
I was trying to fix the door lock problem myself on my Whirlpool Duet Washer GHW9150PWO and I pushed the door lock mechanism down with a screw driver and it locked into place. Of course the door won't close now. Can you please tell me if there is a way to get this mechanism to release without having to have a repair service come out? Thank you.
Posted by jfcwlc on
Frankie Newbold
    Scholar:
  • 92 Answers
Did the screw driver make it out? UNPLUG THE WASHER There are 2 screws at the top of the washer that hold the top cover on. remove the screws and SLIDE the top cover back off the washer. This should expose the door lock assembly, down the right side of the door. There is 1 or 2 screws that need removed and then there is enough wiring that you should be able to pulll the switch where you can work on it.
Now here's the hard part. What probably happened was that the actuator was popped out of its cradle, possibly losing its spring tension. There are clips on on half of the plastic covers(2 halves snapped together). VERY carefully separate the assembly watching for a loose or shooting spring popping out of the covers. If the spring is still on the acauator arm, and hooked in place, good. carefully put the arm back in its cradle. hopefully it snaps in so reassembly is MUCH easier. Simply snap th e assembly back to gether. test the arm with your screw driver to make sure it is springy. Re install the lock where you removed it from the door area. Good Luck.
Posted on Jan 16, 2011
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
We have a whirlpool duet front load washing machine door is stuck closed. i have unplugged machine still wont open?? any solutions i can try myself before i call a repair person??
You can manually unlock it. Unplug washer. On the lower panel there are 3 screws, either 1/4 inch or they are the hex bit. Remove these screws and the panel will come off. Reach up on the inside on the right side. You will be able to feel the door lock mechanism, near the bottom of the mechanism is a pull release lever, pull down on it and the door will unlock. The door lock may need to be replaced. I hope this helps
Feb 28, 2011 | Washing Machines
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet whirlpool ghw9150pwo
Press & hold the button on right of panel 'end of cycle' for 3 seconds, the light will go off. Child lock. <It will come on again if you dont vote me nice!!>
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Controls Locked - How to Unlock?
These are seperate problems, F 02 on whirlpool is a drain issue, this is were you need to remove the three hex screws on the kick panel below the door and using a bucket remove the cleanout on the pump and drain what water comes out and remove the filter and check the pump for damage. The other problem is a duel feature button that needs to be held for 3 seconds to unlock, I am fuzzy on the location, look carefully for the writing blends in with the panel.
Sep 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GHW9150PWO Whirlpool duet
take bottom panel under door off there 3 screws you 'll need a star tool reach on the right hand side there is a yellowgreen strap pull it and door will come open
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet
try hitting pause cancel twice if that doesnt work turn the dial around all the way to off try to unplug the washer if all that fails the remove the three torx screws remove the lower panel and reach up where the latch is after unpluging the washer on the bottom of the latch is a tear shaped tab pull it down till it clicks that will unlock the door
Mar 30, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
180 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
