Try a new spark plug. If you have done that and still no spark, check the flywheel coil leg gap (.012) thousand, should do it. Also, disconnect the kill switch and run a spark test again. If the unit still doesn't have any spark, then in all probability you need a new coil or as they call them today, a new module.
Most Small Engines Use a .035in to .040in Plug Gap.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
