SOURCE: Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
SOURCE: I need hook-up instructions for my 16 Bit Sega Genesis system con
Go to this link.
http://imageevent.com/gamescans/gamemagazines/segagenesismanual
Good Luck
SOURCE: how do i set up my sega genesis
There should be regular av cables and wall adapter for it. Mine came with the wrong cords and that might of happened to you. So if you don't know the av cables go in the back of the tv and plug's in the back of the sega. and the wall adapter goes in the wall. If you don't have the cords than get them off line. Type in:
http://www.amazon.com/s/?ie=UTF8&keywords=sega+genesis+cords&tag=googhydr-20&index=aps&hvadid=2858659671&ref=pd_sl_8zrz6m8bxu_b
cut and paste it online and you can get them.
SOURCE: Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
