Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
Posted on Jan 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u release seat from base - Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Dorel UK
Level 3:
  • Maxi-Cosi Master 1,637 Answers
  • Posted on Jan 20, 2011
Dorel UK
Maxi-Cosi Master
Level 3:
Answers
1637
Questions
0
Helped
454161
Points
2410
Good Evening
At the front of the base unit (nearest to the edge of the vehicle seat) there is a large grey release clip. Pull this clip forward (toward the front of the vehicle) and lift the carseat away from the base. Ensure that you lift the carseat completely away before letting go of the release clip as otherwise it may not release fully and the carseat will still be partly attached.
How do you remove the rear seat of a 2013 Chevy Cruze auto
  1. Open the trunk and locate the seat release levers or buttons. These are typically located at the base of the seat near the bottom of the seatback.
  2. Press the seat release lever or button to release the seat from the vehicle.
  3. Carefully lift the seat up and out of the vehicle.
  4. To remove the seat bottom, pull the seat bottom forward, and then lift it out of the vehicle.
  5. To remove the seat back, pull the seat back forward and then lift it out of the vehicle.
My car seat is stuck in the base
Push down hard on the seat, then pull the release.
Baby car seat will not release
Please contact Dorel USA directly for assistance 63cf109f-f1be-49f7-86f6-b3544b21f439.jpg
My family fix isofix base will not release the maxi cosi car seat We pull the lever and it doesn't release the car seat Is the unit broken or can it be fixed If so how can I fix it Or if it is broken is...
Hi Melanie
To override release the carseat from the base, use a pair of long nosed pliers to reach the wires that are inside the base. They can be accessed underneath the grey button on the base. Pull the wires toward you and the carseat can be lifted from the base.
This is an issue with the base, not the carseat, so the base needs to be sent in for inspection and repair required. Please contact the customer care team for further assistance. 87985515-e848-4733-8df0-f4baae5e6226.jpg
Jan 15, 2014 • Baby Gear
Carseat jammed to easy base 2
Try pressing down very hard on the seat while trying the release. If that does not work, call the manufacturer.
Note: if this does release, check the seat belt for damage before using again. Also check that the belt path used to install the base is/was correct.
-- Marc
Pt cruiser stuck middle seat belt
The problem:
The set belt stop has been lost so the seat belt retracts too far when the seat is laid flat. When laid flat the release mechanism lock as it should when not level. So the seat cannot be raised up as the belt is too tight and locked.
The Solution:
1) Push the two little clips to release and remove the headrests.
Pull the grey lever on the right of the seat base, lift seat base up and forward toward the front seat..
2) See two red capped leversat the back of the two seat hinges and lever them to the upward position, this releases the seat.
Rock the very heavy seat unit upwards and lift complete unit upwards.
3) Take it out of the car and turn 180% so that the back of the seat and base are in the upward position and the seat belt will pull out as it should
4) Replace the missing belt locking stop (I used a tie pin permanently fixed using super glue).
5) Fold seat back down and test then either re-fit seat unit or leave out to decrease fuel consumption..
4helpful
How do you remove the isofix base from the car seat?
Every ISOFIX base has a button which you can press and release the base from the car seat.
Usually it's a round one at the junction of the ISOFIX base and it's LEG
Rear seat belt is stuck in recline position. I recline the rear seat to make room and I can not raise the seat back up. The seat belt is not allowing the seat to raise
The problem:
The set belt stop has been lost so the seat belt retracts too far when the seat is laid flat. When laid flat the release mechanism locks as it should when not level so the seat cannot be raised up as the belt is too tight and locked.
The Solution:
5) Fold seat back down and test then either re-fit seat unit or leave out to decrease fuel consumption.. 2_5_2014_8_03_56_pm.jpg 5f6d2b58-2927-4184-9c82-d111e3a9591a.jpg e9f641fc-5fbc-4c21-a371-ff371d942b1a.jpg a357ac71-d6ed-4dc7-999c-04367d3d6e72.jpg
How to remove the seat
Bubba, Under the front of the seat is a latch that you must release there is a rubber block that must be rotated forward to be able to release the two little knobs that it is wedged between Rotate the knobs inward and lift the front of the seat. the seat will flip toward the rear of the chair and you now have access to the batteries. to remove the seat disconnect the joystick cable from the base and slide the seat forward after you have it tilte back and lift it off the base. Hope this helps you
Uninstall snugride base
The straps should have a release buckle, just pull it really hard while the carseat is removed. Its a lot easier if you put all your weight on the base like kneeling down on it while pushing the release buckle toward the crease of the seat and alternating weight on the base. Good Luck, and remember, you can always cut and replace the belt if necessary!!:)
Top Maxi-Cosi Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
