Turn the player on. HIt the power button again. Push the - or + button and scrool down to what you want. Pictures, music, video etc. then push down the arrow buttons and hit the that should do it.
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music: 1. Off 2. Repeat single Track 3. Shuffle/No Repeat 4. Repeat all Tracks 5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
on some cd players, when they are closed ,they also push a button or little springloaded switch to let it know its loaded. Now eventually these doors wear down and dont quite push the activation switch all the way
yours is inside the box and can sometimes be temporirily jammed down with blue tack or tape
Ive had the same problem and in the end its time to buy another system my friend
Clapster
