The only 'balance' is to adjust the channels relative to each other with the test tones. EFFECT : Use these buttons to increase or decrease the amount of effect applied in a DSP or Advanced Theater mode. When the amount of effect is increased in a DSP/Advanced Theater mode the characteristics of that mode become stronger and more noticeable. The scale ranges from 10-90 with 70 as the default setting. First turn on the DSP/ Advanced Theater you want (by pressing the DSP/ Advanced Theater button until you get the mode) and then increase or decrease the amount of effect. CH SEL : You may want to adjust the channels when listening to some sound sources. Use this button to select the channel you want to adjust. +/- : Use these buttons to select the amount of effect
http://www.retrevo.com/support/Pioneer-VSX-24TX-Receivers-manual/id/386ag014/t/2/
Page 29.
The "Effect/Channel Select" button on the Remote (left of the Menu button), will let you change the level to any channels while listening to a program. Page 22
"EFFECT/CH SEL +/- buttons (See p.38)
in a sound mode and to adjust the channel"
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Cambridge-Audio-540R-Receivers-review-manual/id/2536dj197/t/1-2/
"SW" stands for SubWoofer.
Page 8...
Shows the currently active channels depending on decoding mode and source material. Icons lit indicate active channels in the source material. Icons with a box around them indicate actual channels being output separately.
Search for the word "balance". Page 8 again (circled 8)...
Lights when the Front Left and Right speaker outputs have been set to different levels in the OSD, i.e. a balance adjustment has been made.
You can look at the relative levels of all channels as described on Page 14.
