Question about Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,
I have the espree 536 jacuzzi tub. which heater is required for this unit. i ordered the s750000 but it is the wrong one
US Parts Center
  • Jacuzzi Master
  • 719 Answers
You will have to look to see where the fitting is to install this heater.
there are two styles of heaters they use (mostly)
In-line pressure heater that installs after the discharge of the pump but before any of the jets.
the in-line Vacuum heater installs before the front of the pump in the suction line.
Posted on Jan 17, 2011
I have a espree 536 whirlpool jacuzzi tub the on and off botton doesnt work what could be the problem
Check under skirt and see if gfci receptacle has tripped. If it has you should call electrician.
Nov 03, 2017 | Jacuzzi Home
I have a Espree 536 and need to replace the magic air switch. The tub is enclosed with a tile mosaic front which I do not want to have to remove if at all possible to replace the switch.
it is possible that the switch is held in place by a nut from underneath
see if you put your hand up under the panel to see if there is a nut there
Oct 11, 2015 | Jacuzzi Home
I have a jacuzzi espree 536 model U640. The jets would not shut if with the switch. I unplugged the unit and now it will not turn on
When a jetted tub will not turn off it is usually because the air switch in the motor has quit functioning.
A new air switch for your pump costs around $20
US Parts Center
Oct 27, 2013 | Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
Hello, a few months ago I installed a jacuzzi tub with a Rapid Heat heater. I'd like to clean the tub either by the bleach/detergent method or the granule cleaning packet method. My question is should I...
Any recommended (see the tub instructions) cleaning product should be fine in the heater -- and the higher temperature of the "cleaning solution" should enhance the process. Just be sure to flush the tub's entire system with clean water before you bathe in it again!
Dec 01, 2017 | Jacuzzi S750000 Black RapidHeat In Line...
We have a flexible 1 1/2" line on our tub. Can the heater be installed on a flexible line?
Yes bath heaters may be installed on flexible PVC tubing. it is essentially the same as rigid PVC piping but has flexible properties.
Feb 12, 2011 | Jacuzzi S750000 Black RapidHeat In Line...
I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
Apr 02, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools, Logo
383 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
