Hi The issue is either with the wash pump that is going bad or
the motor itself that is unable to run. As the washer fills and then drains
immediately so the pressure/float switch should also be checked. Hope this
helps...please post back for further assistance. Daniel
Hello friend, thanks for your inquiry!
I see you are experiencing a water issue within your Electrolux washer. It sounds like it could be a problem with your water valve, drain pump, or control board. Since it could be any one of these underlying issues I would recommend having a professional come and diagnose your appliance properly. I hope this helps to some degree. -Matt
I ordered a new pump and motor assembly, I'm expecting it Friday and will install it this weekend. Hopefully your right. Thanks!
Hi Daniel, it turns out it wasn't the pump or motor, it was the motor capacitor, When I recieved the new pump motor assembly, a new capacitor was included with it. After checking the motor again I still didn't believe the problem was with the motor. So just for giggles I swapped the capacitor and it worked fine. To cross check, I tried the new motor with the old capacitor and as you'd expect, it faulted out as main wash pump failure. I can get a capacitor for $8.50, and maybe even less. I will try to send the motor assembly back for a refund. In the future I would maybe recommend replacing the capacitor first? At least on that model dishwasher? It's alot cheaper than $130.00 for a pump.
