Since its very risky and very tough for a person who is not having a knowledge of electronics....to be able to repair it you should know soldering ..a elecronic device know as soldering machine comes through which you can solder all the braked wires.....if you remember where the wires were before, you can do it..just buy a soldering machine ,flux ,and soder wire to fix the wire ..
a
flux is a chemical cleaning agent which facilitates
soldering,
brazing, and
welding by removing
oxidation from the metals to be joined.
Soldering is a process in which two or more
metal items are joined together by melting and flowing a filler metal into the joint, the filler metal having a relatively low
melting point.
Soft soldering is characterized by the melting point of the filler metal, which is below 400 °C.
[1] The filler metal used in the process is called
solder.
Soldering is distinguished from
brazing by use of a lower melting-temperature filler metal; it is distinguished from
welding
by the base metals not being melted during the joining process. In a
soldering process, heat is applied to the parts to be joined, causing
the solder to melt and be drawn into the joint by
capillary action and to bond to the materials to be joined by
wetting action.
After the metal cools, the resulting joints are not as strong as the
base metal, but have adequate strength, electrical conductivity, and
water-tightness for many use
It will be highly appreciated if you could take a minute and provide your feedback..
