Question about Indesit Dryers
Dryer will not spin but heat is still coming out . the dryer is only about 18 months old .
  • 3,074 Answers
Http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Jan 16, 2011
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: bosch wtmc3521 dryer will not heat. Runs, but no
There are two things that could be wrong with ur heater
1 your heating element is bad
2 your thermostat is bad
check those two things and it should be back in order
Posted on Nov 20, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: dryer is 18 months old
Hi jamie duffin...
Here are a few things to check...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 21, 2011
LG Dryer not heating at all. DLG4802W gas dryer. Already replaced two thermostats Thermostat 6931EL3003C and Thermostat Assembly 6931EL3004B and still not heating. Only 18 months old.
Check your igniter, if that does not get hot enough it will not open the gas valve. If it does not glow at all check for voltage if voltage is present 120vdc replace igniter.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Jul 31, 2013 | Dryers
Dryer has Heat but NO AIR
Many of these have a belt driven blower wheel, could be a broken belt or it came off, There was also a bulliten out on several models where the blower wheel would come loose from the drive shaft, the fix was to re attach using a medium body thread lock compound so it would not unscrew again.
Sep 25, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
All of a sudden, my 18 year old Kenmore gas dryer is not producing hot air. The motor is working & the barrel is revolving. What can I do short of spending $500-$600 for a new comparable Kenmore gas...
It sounds like your heating element has given up the ghost and broken OR you have a bad thermostat that isn't telling the heating element to work. I would suggest you find the tag on your dryer with the model number on it and then go to www.searsparts.com and look it up and find the heating element and thermostat and decide if you want to spend that much.
NOTE: Usually, on older models, I always recommend that my client replace both so that I don't have to come back again in a few months to change the other. They seem to both fail close to each other.
Jun 18, 2011 | Kenmore Dryers
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
Bosch wtmc3521 dryer will not heat. Runs, but no
Nov 20, 2009 | Bosch Dryers
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Thermal Fuse keep failing
Fuse and element failure is related to lack of air passing over the element. The drum and fan should run even if the heater is inoperative. Find out what is stopping them, then work on heat. If motor is running, there should be air flow--pull vent hose from wall outlet--should be brisk air flow. If not, remove the lint screen and check again. If now ok, soak the lint screen in hot water and detergent. If drum does not turn, check the drive belt and if it sits properly on motor pulley.
Aug 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer won't spin
This may be a simple broken belt problem. The dryer utilizes a belt that wraps around the drum and is driven by a motor. If the belt breaks, the dryer heating circuits will still finction normally, but the drum will not rotate. It would be helpful if you could provide me with a model number (located somewhere around the door opening, or along the back of the operator console). If it IS a belt problem, this is a fairly inexpensive fix. If the motor, however, has gone bad, it may be considerably more. Please post back with your comments. I hope this helps you.
Jan 17, 2008 | Dryers
Dryers Logo
173 people viewed this question
Top Indesit Dryers Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Gil Shultz
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
