Question about Olympus m:robe MR-500i MP3 Player
Keeps displaying message database error please reconnect to pc
    New Friend:
  • 58 Answers
The first thing I would do is charge the battery fully. Just leave in the cradle overnight. Next, do a blank sync with mtrip (just sync with no files selected). If you're still showing the database error, reflash the firmware and start over. If you're still showing the empty battery...buy a new battery. They're available on ebay.
http://www.mrobe.org/forum/viewtopic.php?f=2&t=1181&start=30
Posted on Jan 16, 2011
6ya staff
SOURCE:
Big pond webmail login How do I reconnect to my previous Telstra Site?
Hi Barry,
Can you please share what is the exact error message you are getting
Keep using FixYa.
Subhankar Ghosh
May 10, 2014 | Computers & Internet
I cannot clear the "Door
Hi
When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. If the cartridge door is not completely closed, the error message displays.
1. Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
NOTE: To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
2. Check the product control panel to see if the error message still displays.
If the issue persists, see the next step.
Check the cartridge door for obstructions
1.Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE: Bits of paper, packing materials, and tape might prevent the door from closing completely.
2. Remove any obstructions.
3. Check the product control panel to see if the error message still displays.
If the problem still persists you need to reset the product...
1.Press the Power button to turn on the product.
2.Disconnect the USB cable from the back of the product.
3.Disconnect the power cord from the electrical outlet.
4.Disconnect the power cord from the product.
5.Wait 30 seconds.
6.Reconnect the power cord to the electrical outlet.
7.Reconnect the power cord to the product.
8.Press the Power button to turn on the product.
9.Reconnect the USB cable to the product.
10.Check the product control panel to see if the error message still displays.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 10, 2011 | HP OfficeJet 7130 All-In-One Printer
Hello I use verifone PCCharge, when I turn it on , an error message pops : "Password backup update failed.Shutting down PCCharge payment server"
PCCharge uses Access database, which is stored in .mdb file. Locate this file. Mine was in C:\Program Files\PCCW\PCCW.mdb.
- Back up this file.
- In the same folder where you found the database, there should be a program called VISDATA.exe. Double click on it to start it.
- Go to File > Repair Database, and point it to your database file (pccw.mdb).
- It will ask you if you want to open db, say no.
- Go to File > Compact Database, and point it to your database file.
- It will ask you if you want to compact to 2.0 or 7.0. I was told to use 2.0.
- It will ask you if you want to replace database, say yes.
- For encrypt, choose No.
- For open, say No.
- Close VISDATA.exe
- Try running PC Charge now.
- If it still gives you trouble, and if you don't mind losing all your history, move the pccw.mdb file out of PC Charge folder (C:\Program Files\PCCW\). Keep it somewhere else for backup, just get it out of PC Charge folder. Now, start PC Charge again. A new database will be created.
Mar 16, 2011 | Computers & Internet
Hello. Could you tell me, please, what "error 8006" displayed at Epson AcuLaser C1000 means?
Error 8006 is a general message that Adaptive Server can raise in a number of situations when working with another Sybase server. The "%S_MSG" in the message text is the name of the server that generated the error.
Most commonly, this error indicates that Backup Server encountered a problem in running the dump database or load database commands. When you issue a dump or load command from Adaptive Server, the server interprets the command and sends remote procedure calls (RPCs) to the Backup Server. As dumps and loads execute, Adaptive Server and Backup Server use RPCs to exchange instructions and status messages. Thus, an 8006 error during a dump or load is typically accompanied by additional messages originating from the Backup Server.
Jan 31, 2011 | Computers & Internet
I get this error message.. an error occurred communicating with the scanning device. Please ensure that the scanning device is connected properly and try again. Nothing seems to work,, this message...
#Click Start , select Settings , and then click Control Panel .
#Double-click System . The System Properties dialog box displays.
#Click the Hardware tab.
#Click Device Manager . The Device Manager dialog box displays.
#Click the plus sign (+ ) next to Universal Serial Bus Controllers .
#Click the USB Composite Device entry, and then click Remove .
#Disconnect the USB cable from the All-in-One, wait for few seconds, and then reconnect the cable. The New Hardware found dialog box displays.
#Click Next through all of the screens that display while the Wizard installs the USB composite device, and then click Finish .
Regards
Riztech
Oct 24, 2010 | HP Officejet 7310 All-In-One Printer
Error Message On Hp PSC 2355
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try it not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | HP PSC 2355 All-In-One InkJet Printer
Keperksy Internet 2009: Error message:
try to update your kaspesky online to resolve the database corrupt error.....usually this error occurs whenever you restore your pc to a previous date that make your database corrupted...goodluck
Dec 11, 2009 | Kaspersky Labs Internet Security 2009
OmniForm 5.1 , Database error
OMNIFORM 5.1 IS INOPERATIVE, KEEP RECEIVING PRINT SPOOLER AND KERNEL PRINTER ERROR MESSAGES HAVE TRIED TO REPAIR, AND DELETE AND RELOAD. ALL ATTEMPTS HAVE FAILED. THESE PROGRAMS ARE BEING USED ON WINDOWS VISTA
Feb 20, 2009 | ScanSoft Omniform Developer Edition 5.1...
Olympus m:robe MR-500i MP3 Player Logo
144 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
