Hi
How to remove and unlock hard drive password? Is there any software to recover hard drive disk password? Where to download hard drive password cracker? Is it possible to reset the hard drive password?
According to manufacturers' website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
Most people are not aware that most hard disk drives have the ability to set a hardware password, just like the Bios password for motherboards, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. Usually these features can only be found in laptops, this is when you set a password on your notebook, the hard drive together with the motherboard becomes locked.
Most experts would say if you forget the original HDD or Bios password, there is no way of restoring it by generic system tools. Unlike the Bios password where there is a master key or with the removal of the bios battery, the password is erased from the flash memory thus the settings is restored to factory settings without the password, however, this does not applies to hard disk.
HDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. IDE and SATA hard disk drives are supported. Both User and Master password can be removed. Please note that while unlocking, HDD Unlock Wizard will erase and re-certify the drive, meaning to say all data in the disk is lost and not recoverable. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard drive usable again. Download HDD Unlock Wizard now! 2.8MB only!
It may not be possible to recover the hard drive password or to unlock it; however, it is possible to remove the password together with the data, thus making your hard disk accessible and usable again.
During the boot up process you will see on the screen press delete to enter set up
Press delete during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
