Canon PowerShot A720 IS Digital Camera Logo
Posted on Jan 16, 2011
Battery drains very quickly, in 5 to 10 minutes.
24volt system draining fully charged batteries within 30 minutes down to 2 volts each and ignition doesnt turn bus off have to stall it have to remove battery to turn dash lights of has new alternator
to drain the batteries down that quick the battery cables would be very hot to the touch
if they are not then the problem may be an internal fault in the batteries so have them load tested first to eliminate them from the equation
Unless you are running a heavy vehicle then 24 volts will be very unusual as most light vehicles run 12 volts
If that is the case and you have 2 X 12 batteries make sure that they are connect correctly ( in parallel not in series) or they will discharge each other very quickly
1helpful
What does it mean when my kindle fire hd gets too hot after a few minutes of using it?
Do you notice your battery draining quickly? When your battery drains quickly, it heats up. This can happen if you are running many things at once, or if your battery is getting old.
My nokia 9300 battery is getting charged within 15 minutes and drain quickly
The battery is bad and you have to get a new battery.
If you want to get your battery, make sure you you go to the NOKIA to get the original battery.
Regards.
Jun 20, 2011 • Cell Phones
The only problem with the camera is that i have to change the batteries every 10 minutes is there a way to fix it?
Because of the power drain due to the functions you use and the resolution of your pictures, alkaline batteries in digital cameras will drain fairly quickly. The best bet is to get some high capacity rechargeable NiMH AA batteries (at least 2500MAH). This should give you the photo taking life your want.
I would get at least 6 rechargeables (the 15-minute rechargeables) so that you have a couple of changes available and you can quickly recharge them.
Let me know if you have any other questions.
Please rate this solution. Thanks.
2helpful
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
1helpful
Peugot expert van draining battery when everything is switched off When jumped started the battery charges quickly, but switch off the engine and in ten minutes the battery is totally drained. Help greatly...
either change the battery or the alternator,,just either of those,,,if your battery is no good it wont hold charge when started,,,also if your alternator is no good it wont charge your battery when engine is running,,,(it can also drain your battery if faulty)..get a second hand alternator in a breakers yard maybe a batt too much cheaper,,,hope i helped you,,
2answers
Quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
Batteries Dying Quickly
Change the internal rechargeable battery.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
