I M TOTALY IMMATURED IN THIS PROFRESSION CAN U HELP ME BY MAILING THE STEPS ONE BY ONE
Hi yashb22,
Connecting to the internet using your psp is almost the same as connecting through your laptop. If you're having connectivity issue please try to check the error. One of the common error is WLAN switch is off, so make sure that it's properly toggled to the right. If you've already checked and still can't connect try doing the following steps below:
1. Make sure to turn on your PSP as well as the wireless/WLAN switch.
2. Then Navigate to " Network Setting".
3. Select "Infrastructure Mode".
4. Now Select "New Connection" and Name this connection.
5. Navigate to "WLAN Settings" Select "Scan".
6. Your router should now be listed.
7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None".
8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA.
9. Then navigate to "Address Settings". Select "Easy".
10. Go to "Setting List". Verify that your settings are correct.
11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection.
Hope this information will be helpful.
Thank you for using FixYa.
SOURCE: how can i download games for my new psp-3004?
Nice try, but this does not apply to his or this psp. aka the 3000 series (lite). As of now there is no hack for the lite psp. The solution that chris is posting is for the phat or og psp that first came out. The 1000 series. You cannot go back to 1.50 on a slim psp. Because there was none made with 1.50fw. If you try to downgrade your psp you will brick (kill) your psp. The only way you can d/l games is through sony's psn store and there all psx (PS1 games). And you have to pay. Any more question pls feel free to ask.
SOURCE: how to hack psp 3004
The newer PSP models cannot be downgraded. You need an earlier model (ie 2.0 psp and previous)
SOURCE: from where to download free games for psp-3004
If you go to some sites like psp-vault.com you can find games people made and put up for other people, but they can be kind of hard to use, so be sure to read the instructions.
SOURCE: how downgrading a psp from 5.51 on psp 3004
you cant. but 5.51 didnt do anything noticeable to the psp
