This
calculator does not support the modulus operation directly, you have to
simulate by a divide followed by a subtraction and a multiplication.
Suppose you want to calculate 256 mod 17:
SOURCE: how do i use the casio fx-991ms calculator to get
With the present value on display, key in:
x 0.22 =
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
SOURCE: how to calculate log value in calculator with different base value
to calculate logb to base a,perform logb /loga
SOURCE: how to calculate 24124 mod 19937 in casio fx-991Ms calculator
The MOD function simply returns the remainder that is left over after dividing the two numbers.
In this case, its possible to see quite easily that only 1×19937 can be taken from 24124 before the remainder is less than 19937. The MOD function is therefore the same as 24124 - 19937 = 4187.
In cases that are less obvious, do the division, ie 24124 ÷ 19937 = 1.210011536[34]
[The last two digits are hidden on the display but still used in subsequent calculations].
Then obtain the fractional part by subtracting 1 to give 0.210011536[34]. Then multiply the answer by 19937 to give 4187. Assuming that you haven't cleared the screen between each section of the calculation, the screen will show "Ans×19937 [=] 4187".
SOURCE: How can find the value
Press 2 ^ 8 =
The ^ key is just below and right of the big cursor pad, above the sin key.
