Question about Microwave Ovens
How do we reset our freezer? Is sitting at -20 C and cant set it, way too cold. Can you tell me what site l can get onto to downlowd the user manual l have misplaced mine. Need attention asap.
Posted by designertan on
specialistel
    Brigadier General:
  • 8,909 Answers
Minus 18 is correct for a freezer so minus 20 isn't far out.
At minus 18 or Zero Farenheight, is where bacteria stops developing and food keeps for years.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
I hope this helps.
Posted on Jan 16, 2011
How to set clock modelEM925EYP
Please, go to this site and download the first link user's guide, it should explain on how to set the clock.
http://www.manualsdrive.com/results.php?lang=en&search=Homemaker%20microwave%20em925eyp&#.VQINgrVH0sk
Mar 12, 2015 | Microwave Ovens
American fridge freezer power on lights on in both sides. Set to maximum cold setting but freezer temp is only just lower than fridge, which is not as cold as it would normally be.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 10, 2011 | Bosch Microwave Ovens
Not cold and when you open door you cant here blower working. the freezer is cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | Microwave Ovens
Icing up on inside regulator not working properly, thermometer slipping leakage drain at back blocked water draining out onto floor
heatman101
Jun 08, 2011 | Microwave Ovens
Looking for a manual for Artica Eco Lockhart freezer, range -22/-15. Keeps automatically going onto defrost mode and I don't know the panel settings to keep it under. Would be very grateful for any...
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 28, 2010 | Microwave Ovens
I have a black normende microwave..i lost the user manual and cant set it properly its working fine but i just cant get the setting on to heat it
I suggest you contact Nordmende, their web site, from there you should get access to what you require.
Oct 19, 2010 | Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
