Gaggenau 15 in. VG 353 Gas Cooktop Logo
Question about Gaggenau 15 in. VG 353 Gas Cooktop
I need the two front knobs that come out from the front lower inside unit that are the igniter controls for tge gaggenau vg 353 112 cd. Please lead me to the part numbers and a parts supplier. Thanks brian
Posted by Brian Sanger on
Anonymous
    New Friend:
Here are the diagrams, parts list, and sales of the parts. Specific to Gaggenau VG353. Additional site to order parts: Essentials For Your Home website, just put in the part number from the diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232110&diagram_id=193996#d193996
Posted on Sep 19, 2012
1 Related Answer
Anonymous
  • 130 Answers
SOURCE: Gaggenau VG-352-812 Cook top
You should be able to go online to Gaggenau and in the service area there is a link for order parts
Posted on Jan 06, 2008
How do I unlock my Gaggenau CI282 induction cooktop? I tried pressing the key symbol for 5 seconds and restart it. Nothing works.
Display cleaning protection
If you wipe over the control panel while the hob is switched on, settings may be changed. To avoid this, the hob has a function you can use to lock the control panel for cleaning. To activate: Remove the twist knob. An audible signal sounds. The ? indicator and the hob settings flash. The control panel is locked for 10 minutes. You can now wipe over the surface of the control panel without altering the settings.
To deactivate: Put the twist knob back on within 10 minutes. The control panel is unlocked. To end the function early, put the twist knob back on before the 10 minutes have elapsed.
https://www.google.com/search?q=Gaggenau+CI+282+unlock+cooktop
No flame touching thermocouple
There must be a blockage on the inner flame ring as the gas is not getting to the thermocouple .
1helpful
My 5-burner 36" gaggenau has stopped working. I
Hello.
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Gene
Cook top burner knobs all 4 not able to turn
Just to be clear, non of the 4 burner controls/knobs will turn ? You are familiar with this unit are you ?
Typically you must push down and turn to activate them.
Let me know if that is not the solution.
Good Luck :)
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
The elect. igniter will not turn off with the knob.
Spark switch at the valve needs to be checked/replaced.
Jammed knob on Gaggenau cooktop
It looks like the gas valve for FR burner has to be replaced. Very unusual for Gaggenau gas cooktops.
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 • Cooktops
2answers
Gaggenau clicking
Sounds like the spill got into one of the burner switches. This is not a big problem. Once it drys out it should return to normal. However if it keeps on clicking it could mean that one of the switches shorted out and will need to be replaced. The switches are located under the burner control knobs on the valve. Hope this helps. Catriver
Top Gaggenau Cooktops Experts
Paul Carew
Tall Tiger
Tall Tiger
ADMIN Andrew
ADMIN Andrew
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
