Question about Nintendo Wii Fit - Balance Board + Game Console
My wii fit balance board thinks i'm on it all the time...it constantly says to step off and press A
Posted by krsboles on
Ivy Cada
    Genius:
  • 1,098 Answers
HI there.
You need to re seat the sensors.
I have written a great tip with video. You can find it here.
Thank you!
Posted on Feb 06, 2011
My wii balance board think i'm on it when i'm not always says step and press a
HI there.
Thank you
Jan 01, 2011 | Nintendo Wii Fit - Balance Board + Game...
The board keeps asking me to step off when I'm not on the board. It won't work with any game. It thinks it has someone on it when there isn't.
Hello :
Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom
(such as carpet), try using the foot extensions
If you are you using the Wii Balance Board on a plush carpet , try using the foot extensions. After you have installed the extensions, re-weigh yourself and check for proper results (within a few pounds.
good luck .
rate please !
Mar 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board keeps telling me to step off and press (A) even though i am not stood on it
iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
Jan 29, 2010 | Nintendo Wii Fit - Balance Board + Game...
We used our wii fit on another wii system. After
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
Hope it helped.
Nov 22, 2009 | Nintendo Wii Fit for Wii
Please step off press A - constantly repeated - why???????????
If the Wii Balance Board fails to operate, or operates incorrectly, follow the steps below before seeking
assistance.
A. Check the batteries.
B. Check to be sure there is nothing pressing against the bottom.
C. If you are using it on soft carpet, put the foot extensions on.
1. The Wii Balance Board does not respond.
• Make sure the power is turned on. The blue Power LED should be lit if the Power Button has been
pressed. (The Power Button faces away from the TV.)
• Make sure the board has been placed correctly (see page 6).
• Make sure the batteries have been inserted correctly and are not been depleted.
• Make sure the game you are playing is compatible with the Wii Balance Board.
• Review the synchronization procedure on pages 7-8 and make sure this has been done correctly.
This procedure must be done for each Wii Balance Board compatible game.
• If, after verifying the steps above, the Wii Balance Board does not work, try the following:
1. Turn off the power of the Wii console with the POWER Button on the front of the console.
2. Unplug the power cord from the wall outlet for a few seconds, then plug it back in again.
3. Turn on the power of the Wii console.
4. Repeat the steps in this Operations Manual for setting up the board.
If the Wii Balance Board still does not work, follow the information at the bottom of this page.
2. Control of the Wii Balance Board is inconsistent or seems incorrect.
• Review the Instruction booklet for the game you are playing to make sure you are performing the
correct actions for that game.
• Try using the Wii Balance Board foot extensions if you are using the board on carpet (see page 10).
• Make sure there are no people or other objects between you and the Sensor Bar.
• Avoid interference from other devices. If communication seems to be affected by other devices
(wireless LAN, microwave ovens, cordless devices, computers) move to another location if possible,
or turn off the interfering device.
If the Wii Balance Board still does not work, follow the information below.
If the Wii Balance Board still does not work, an operational check procedure is available
in the Options Menu of the game you are playing. See the Instruction booklet included
with the Game Disc for more information. If your Wii Balance Board does not operate
correctly after all of the above steps, visit support.nintendo.com for assistance and
additional troubleshooting and repair options or call 1-800-255-3700.
Jul 19, 2009 | Nintendo Wii Fit for Wii
Wii board keeps telling me to press A
most likely a bad board or cable. There is a short somewhere
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Apr 23, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
My wii fit balance board says to step off and press A
You need to load it, stand on the board, step off, and then press A. I have a WiiFit and that happens. It expects you to be standing on it.
Mar 27, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
"Step Off Me and Press A" message while not on wii board
When you get this message, lift the board off the ground, press A, and wait until you get to the confirmation screen before placing the board back on the ground. You may have to try a few times to get the timing right. I have no idea why it thinks someone is on the board, but this workaround has solved the problem for us. Good luck.
Jan 04, 2009 | Nintendo Wii Fit for Wii
Wii Fit Board asks me to step off and press A all the time
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 04, 2008 | Nintendo Wii Console
Power
    Try these steps!
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit - Balance Board + Game Console Logo
322 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
