Question about Aqua -Vu Perch Underwater Camera with 100-Ft. Cord GPS Receiver
We are experiancing probems with our agua view. The light comes on on the moniter but there is no video coming through. Is there a fix for this issue
Posted by rpillon624 on
  • rpillon624 Jan 16, 2011
    We are expriancing problem problems with our aua view underwater camera. the light comes on but the video does not come through.
travelbobgau
    New Friend:
    Problem Solver:
  • 6 Answers
I was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Posted on Mar 05, 2011
How do i get the night vision picture to come in better on the moniter
INSTALL A EXTERNALL ILLUMINATOR IN VIEW AREA IT HAS IT'S OWN POWER SUPPLY , AND NEED NOT BE NEAR CAMMERA ONLY IN IT'S VIEW AREA THIS WILL INCREASE BRIGHTNESS OF VIDEO IN DARKNESS
Jun 24, 2014 | Lorex 4 Channel Home Surveillance System
Question about my HP desktop model p6-2003 computer blue light on and moniter going to sleep moniter going to sleep
in control panel, select the power Options,, Change the preffered plans to HIGH PERFORMANCE then click on change plan settings, change turn of diaplayto never and put computer to sleep never... Remember to turn on your screen saver and put the pc to sleep manually when not using it.
this is a common problem and caused by corrupted registry entries. The popper fix is to reformat or restore the system.
Dec 29, 2012 | Computers & Internet
I have desktop pc motherboar asus m2m ddr2 ram display not come extra display card attached but display not com in moniter when press on keyboard num lock o n off system boot ok but display not come in...
re-boot pc. Go into setup (F2). Go to your video settings and make sure your video card is selected as your video device and that setting are correct for its operation.
Dec 04, 2012 | Computers & Internet
Micronpc Clientpro Three beeps on start. moniter does not come on has good video board
Check to be sure RAM is seated correboot up.ctly. If it is replace with known good RAM and re-try
May 20, 2009 | Compaq Deskpro EN PC Desktop
On button is orange and moniter wont come on
If the PC is on and running and the light is oragne it means your video card is bad or the cable is loose.
Power off your PC (gonna have to hold the button down on PC until it turns off) and then turn off the monitor.
Reseat cables on both ends from Monitor and PC then power back on again and see if that helps.
If it still doesn't work you have a bad video card.
Hope this helps
TankMurdock
Apr 24, 2009 | X2Gen MG19VT 19" LCD Monitor
Scanport N7 LCD Monitor won't stay on
it seems a whole lot of people have moniters with fatal ailments as i do as well. after spending $ 150.00 at computor stores & still had the same problem with my Moniter I just orderd another new moniter & the Problem is fixed..
I Think there killing moniters on purpose
Jan 15, 2009 | Scanport 17" LCD Monitor
Moniter is black
hi sounds like you need to replace the lcd backlight which lights up your cd display when it goes you can still see things but it's very dim if you need help ordering that part let me know and i'll find you the product code hope this helps
Aug 08, 2007 | Balance CN6555 Notebook
GPS Logo
360 people viewed this question
Top Aqua GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Aqua GPS Expert? Answer questions, earn points and help others
