SOURCE: Wireless internet problem!
OK I have found a tutorial link.. Work thru the tutorail ..hope this helps.. http://www1.euro.dell.com/content/topics/global.aspx/solutions/truemobile?c=uk&cs=ukbsdt1&l=en&s=bsd&~tab=3 It is possible to do exactly as you want.. so it is simply a matter of getting all the setting A OK.. G L. :)
SOURCE: wireless router does not work with pc
Since you are able to ping remote address it shows that Router has no problem. Its more at the computer side. Since you haven't indicate your operating system I will give you general troubleshooting steps. reset the Internet explorer settings (If you are using Windows XP you can uninstall-reinstall the Internet explorer).
Also you can check and reset firewall settings.Please inform the outcome and your questions if you need further assistance.
Good Luck
SOURCE: Dell Wireless 2350 Router
Connect one of the router's LAN ports to the computer, no other connections to the router.
Reset the router to factory defaults by holding the reset for 15 seconds with power on.
Reboot the computer.
Start, Run, cmd /k ipconfig
The address of the Default Gateway is the base address of the router, type that into IE to access the setup pages.
SOURCE: Router problems
Try to reset again the router follow this steps in resetting it, Press and hold the reset button of the router for 30 seconds while the power is ON , then after that unplug the power of the router for 10 seconds and check if all the lights are now back to normal if still no and router is still under warranty better have it replace because router is already bad........
Hi dgperris, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
do you know how to log into the router as admin ?
can you check the wi fi settings and see if wi fi is enabled in the settings. As I had a router that would randomly disable this setting all by itself ?
