Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi vs50705 turn power on green button comes on then it shuts off quickly
Posted by kellist on
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
TRY the self check here, this model may have it.
When green light comes on and goes off, on front of set press and hold both the menu and input buttons for at least five seconds and release both buttons.
Watch the power light, if it has the self check feature it will blink a two digit error code.
The most common is two blinks, two blinks, a pause and then repeat several times.
Let me know if find a error code.
SD TECH
Posted on Jan 16, 2011
When we push the power button on the remote or on the tv the green light comes on for one second and then shuts off ... tv won't turn on
you have a short circuit in the power supply.
1) test the power cord very well
2) test the main swithc for short or open
3)test the power supply, look for a short in transformer+coil+filter+diode+rectifier. and replace
4)test the HVRECT+fLYBACK+ horizontal output for +125Vdc +vertical output for +80Vdc ALL this go to the CRT
color +12vdc+other circuit +12vdc. The first thing do you will have is RASTER, see the block. d
God bless you
Jul 31, 2012 | Mitsubishi WS-65819 TV
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Won't turn on after reset ws-55511 hdtv
YOU GOTTA REPLCE THE STK ICS OR THE CAPS ON THE DM BOARD
Jul 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Jul 15, 2009 | Mitsubishi WS-65819 TV
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Blinking green light
Please verify Model # and mo / yr built off back of set...
critical for correct solution........T.
Dec 02, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Tv shuts off
You could have a problem in the sweep or main power supply, Bad capacitors on the DM module, they will be all grouped together and have swollen tops, Coolent fluid leaking out of one of the CRT's. If you have no electronic or solid state repair experience, please get a pro to assist you in this repair. Good Luck
Apr 03, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
