If your Mini Hi-Fi component system is displaying an "eject" message and then switching off, it could indicate a problem with the disc tray or the system's eject mechanism. Here are a few things you can try to troubleshoot the problem:
Check for any foreign objects in the disc tray: If there is an object blocking the disc tray or preventing it from closing properly, it can cause the system to display an "eject" message and switch off. Remove any foreign objects from the disc tray and try turning the system on again.
Check for any damage to the disc tray: If the disc tray is damaged or bent, it may not be able to close properly, which can cause the system to display an "eject" message and switch off. If you notice any damage to the disc tray, it may need to be replaced.
Check for any damage to the eject mechanism: If the eject mechanism is damaged or malfunctioning, it may not be able to open and close the disc tray properly, which can cause the system to display an "eject" message and switch off. If you suspect a problem with the eject mechanism, it may need to be repaired or replaced.
Check for any other visible issues: If you don't see any obvious issues with the disc tray or the eject mechanism, there could be another problem causing the system to display an "eject" message and switch off. You may want to try unplugging the system and plugging it back in to see if that resolves the issue, or you can try resetting the system according to the manufacturer's instructions.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the system serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
tell all things connected, and did not(in detail or photos)
what are you plugging in.(all)
I can buy endless speaker systems and no 2 are the same.
no speakers told, (hardwired, amplified, or what?,)
bad speakers, or bad RCA cables.
bad RCA output jacks on rear of g88 (preamps bad)
or PC end failing,
if I knew all you had there all makes and models and connections exact told , I can in fact tell you tests to do.
IT IS NOT A COMPUTER IT IS A home hi-fi player CD etc. It is 20 years old today, find this at a garage sale dead? CD. Mini Hi-Fi Component System SO ALL WORKS PERFECTLY but the CD Tray button? ????????????????????????????????????????????? page 38 in you manual states if the disc tray does not open and "LOCKED" appears. • Contact your Sony dealer or local authorized Sony service facility
or make sure sleep timer in the HI_FI rig is turned off
i hv also this problem from yestrday.. all function are ok. bt when playing dvd ... there is 'please wait'error long time. and also tray not open after pressing open or exchange cd also... whats problem.. please help me.. waiting
