SOURCE: i want to download a
Hi.
Please use this driver download page: Epson Stylus Photo R230
Download and then run the driver files from the page above. Ensure that you select the correct driver for your operative system.
Here also a tip with driver pages for different printers How to install a printer is a driver software...
Regards.
Ginko
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
SOURCE: EPSON Stylus Photo R230 Series - Driver Download
Hi dear, you can download your required driver free from the following links;
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=1&pid=950
http://www.epson.com.sg/epson/drivers/driver_download.htm?mode=2&productModel=1
http://driverzone.com/device.php?id=12567
Good Luck
SOURCE: Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
SOURCE: how to install EPSON Stylus Photo R230 without cd
You can install the printer by downloading the software from this link.
