EnGenius SN 900 Ultra-1 Phone (SN-900Ultra-1) Logo
A
Anonymous Posted on Jan 15, 2011
I have an Engenius SN-900 Ultra Base unit with 2 handsets. I have registered 1 handset, but can't register the second one. When I press Menu, then 6, and 1 to Register, it handset doesn't respond. If I press 6 and then 3 and *, I get: Enter base ID (1-4) ? When I press 1 or 4, I get Reset all. If I press 6 and then 4 and *, I read: Dereg from all bases. Can you help me solve this problem?
2 Related Answers
otacon
Damen Wong
  • 1950 Answers
  • Posted on Jan 01, 2008
SOURCE: Can not get the second handset to register to the base
After you got the no connection message after trying to register the second handset...did you try to register it again?
gary wittingslow
  • 18 Answers
  • Posted on Sep 30, 2008
SOURCE: register handset to base unit
press menu 6 on handset then press base station reg key for 2 sec till L1 L2 L3 L4 LIGHTS FLASH
handset should now show registration no between 10 and 99
2answers
This is the registration procedure
Step 1: press MENU-6 and select 3 “SET BASE”
Step 2: press the REG key on the master base
Step3: press register to finish the registration procedure.
• After the registration complete, handset 11 and handset 21 can
2-WAY intercom with each other
If issue persists reset the unit start registration by using 2nd unit that currently unable to register. if issue continues please inform for further troubleshooting
Good Luck
2answers
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
I have a model KX-TG9332T.... I cannot get the handsets to link with the base...I have unplugged, moved the system, changed the batteries and both handsets continue to get the message cannot link to the...
Registering a unit Operating additional
handsets
Additional handsets
Up to 6 handsets can be registered to
the base unit.
Important:
L See page 6 for information on the
available model.
Registering a handset to a
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, register the handset.
Handset:
{MENU} i {#}{1}{3}{0}
Base unit:
Press and hold {LOCATOR} for 4
seconds until the registration tone
sounds.
L If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
L The next step should be
completed within 90 seconds.
Handset:
Press {OK}, then wait until a long
beep sounds.
{OFF}
Note:
L While registering, "Base
registering" is displayed on all
registered handsets.
L When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
4helpful
2answers
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
35helpful
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Register handset to base unit on sn-920
Cordless phone EnGenius SN 920
. A new handset arrives with a handset ID number of 00, to register this handset to your system take the following steps:
  1. On the EnGenius base unit press and hold down both the "Volume" & "Intercom" buttons for about five seconds. You will hear a beep from the base unit. You can now release the two buttons.
  2. On the EnGenius handset (00), press the following buttons: "menu", "6", "1".
  3. A new handset ID number (ie: 12, 13, 14…) is automatically assigned by the base and registration is complete.
2helpful
3answers
EnGenius DuaFon 1X
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
ID Conflict with Base 1 error
hold the volume and intercom buttons together the in use light will come on and then go to menu on handset press 6 then 1 to regester that should work i just talked to a friend with a telecom buisness and he told me what to do with mine good luck
Top EnGenius Lands Phones Experts
k24674
Are you an EnGenius Lands Phone Expert? Answer questions, earn points and help others
