My Mum Recently Found A Blackberry Curve 8520 In The Back Of A Taxi, So She Gave It To Me Hoping That It Would Work,And It Didnt, My Sister Spent A Large Amount Of Money Trying To Get It Unlocked And To Get A New Sim Card For It. But It Wont Let Me Send Or Receive SMS And Calls, We Think It May Have Been A Contract Phone On The O2 Network And We Also Think It Has Been Blocked Seeing As It Could Have Been Reported Lost Or Stolen, Is There Anyway That I Can Get It Fixed?
Hello, You can easily unlock your Blackberry cell phone,Simply enter unlock code through mobile keypad,You can get unlock code by BLACKBERRY CURVE 8520 UNLOCK CODE provider with Instructions. THANKS ! ! !
I think your password to unlock screen is not correct one, try to remember your password again. If still not remember and you need that phone so urgent, you can unlock blackberry curve 8520 screen password by typing any password until you fails 10 times. Your blackberry will be erase all your data including your password and you can setup new password again after your blackberry unlocked. Good luck!
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
The fastest way to reset your BlackBerry Curve 8520 back to factory settings is to peform a security wipe. it will result in the loss of all user data! It is recommended to perform a backup of the BlackBerry 8520 data. .
To reset BlackBerry Curve 8520 to factory settings:
Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Hope this helps, if so do rate the solution
If you are locked out you can enter the wrong password several times and the phone will restore to factory settings. The downside to this is you lose everything unless you used the backberry server and saved!
How To Unlock a Blackberry Curve 8520
1. Turn on your Blackberry Curve 8520 phone with your current network/service provider’s SIM card. 2. Using the menu go to Settings Menu -> SIM card and press select. 3. While holding the SHIFT key, type mepd. 4. You should now see the five locking categories listed. 5. While holding the SHIFT KEY, type mep2. 6. Release the shift key. 7. You will now be prompted to enter the Network MEP code. 8. Enter the Unlock Code. 9. Enter Return/Enter. 10. Your Blackberry Curve 8520 phone should then be unlocked.
Now you should have yourself a fully unlocked Blackberry Curve 8520. Before you can use your newly unlocked phone on a new phone carrier’s network, you must buy a SIM card and order a voice plan with that carrier. If the steps above did not work on your Blackberry Curve 8520, do not try repeating as this could just permanently lock your mobile phone.
