We have a Passage-2 luggage lock that my husband has forgotten the 3 digit code to. how can we reset it to get it unlocked and set up with a new combo?
Re: We have a Passage-2 luggage lock that my husband has...
If you have forgotten the combo the only way to get the lock to open is to ' progress ' the combo wheels. since it is only a 3 digit combo - this will take anywhere from 15 to 40 minutes.
start with 000 then 001 then 002 etc... all the way to 999 ( but you will get the combo before 999 is reached ). after the combo is found, with the latch open push the lever to the to open position and set the new combo that you want.
Lock code:
1. 5 digits, Used to prevent unauthorized access to certain functions on the phone
2. Where: Tools > Settings > Security > Phone & SIM
3. Default: The default lock code for Nokia Series 60 devices is 12345.
4. Forgotten - If you've changed this code and forgotten it - you will need to visit a Nokia authorized service center, who will be able to reset the lock code for you.
PIN code
1. 4 digits, an optional 4 digit code to protect your SIM
2. where: Tools > Settings > Security > Phone & SIM
3. Forgotten -If you keep trying, you'll eventually get locked out and need to contact your network operator for a PUK code
PUK code
1. 8 digits, You'll be asked for this 8 digit code if you've entered the wrong SIM code more than the allowed number of times. You'll need to contact your network operator to get this lock lifted.
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock.
With the Combination
Step 1
Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
Step 2
Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
Step 3
Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination
Step 1
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2
Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3
Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination
Step 1
Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Step 2
Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Step 3
Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Step 4
Roll the dials until you have your new combination.
Step 5
Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals! www.alibaba.com$0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now! www.hostgator.com/1PennyRooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now! www.airconditionings.cnDownload Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now! www.facebook.comby Taboola Sponsored Links Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft RecipesSee Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
Do not open a lock that does not belong to you. It is against the law.
ABOUT THE AUTHOR
Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
You can not reset your lock combination without knowing the original combination you had set.
If you have forgotten your lock combination, then there are 2 solutions.
1. You could use Bolt Cutters to break the Lock open.
. Sometimes, the simplest solution is often overlooked, as your lock is
a 3 digit combination lock, and if you have about 30 minutes to spare,
then why not try all the possible combination from 000 - 999 ( 000,
001, 002, 003 through to 999) You may think this will take a long
time, but it should not take you more than 30 minutes and if the first
digit of your forgotten code starts with a 0, 1, 2, or 3.. then it will
take significantly less than 30 minutes. Try it out, as it will save
you from having to buy a new lock if you use bolt cutters.
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad
To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
Enter the permanent factory code.
Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment.
To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s).
To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) .
To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.)
This will turn off courtesy lamps and arm anti-theft alarm control (if equipped).
To program an alternate code:
Enter the five digit permanent entry code into keyless entry keypad .
Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
Enter any alternate five digit code within five seconds of pressing 1/2 button.
Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
9/0 — no memory recall
1/2 — memory seat position 1
3/4 — memory seat position 2
5/6 — memory seat position 3
After successful programming, the doors will signal by locking and then unlocking.
Keyless Entry Keypad Does Not Work Properly
Circuit.
Keyless entry keypad.
Electronic door lock control processor.
Open Fuses:
Town Car and Crown Victoria/Grand Marquis
Power Distribution Box (under hood)- K, 40A (Maxi)
