Often there is a "change screen-mode" button on the remote that changes between Zoom and fit to screen, normal Auto zoom and others, have you tried that?
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB.
-Ken
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
it sounds like you have hit the zoom button or your aspect ratio isnt right. the aspect ratio should be set to 16:9 (if there isnt a button for aspect ratio, change it in the menu) and there should be a zoom button on your remote and just keep hitting that and it should return to normal. If neither works, post your tv brand and model and i'll try to find another answer
Have you tried the "Format" (*) button on the lower left hand corner of
the remote? That cycles through the HD 'normal', 'stretch', 'partial
zoom', etc modes (I may not have the precise names here).
If you are using Dish Network, while in SAT mode, hit the star key on the remote (also labled FORMAT). It will start scrolling through certain modes: zoom, partial zoom, normal, stretch... etc)
