In your owner's manual (available free online here) this is called the "microwave inlet cover".
See the tag in your oven cooking cavity or near the door frame for your full model number.
The cover is located in the ceiling of the oven.
You should be able to remove and clean or replace the cover without removing the oven from the wall.
The oven installation instructions and parts list are also on that page.
You can also find handy exploded views and order any needed parts and accessories by model or part number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
If there is spark please do not switch on
unless you have confirmed the fault. It is possible that the Magnetron is
leaking and sparking to the ground. As you have mentioned it was stored, it is
quite possible that insect can get into the oven and create soft spots. When
you switch on these will create a short and make the voltage jump and in the
long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if
so wipe clean and dry, check the magnetron and area clean and use an jet air to
clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can
be faulty. Replace with same type. If not check the waveguides within the cabin
for food particles that can burn and spark, check for rust that can corrode and
spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
