SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
SOURCE: Canon pixma MP600, error code 5010, what does it mean
There are a few things you can try:
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Testimonial: "Thenk you very much for your assistance, I will try your solutions. regds Robert"
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found
the cause. As others had pointed out before, it can have alot to do
with some obstruction in the print path, the gears, or ink on the clear
plastic encoder strip. You're on the right track - I found the the
purge cap (the white sliding mechanism that the print head parks to
when it's not in use) was not lubricated well enough from factory. If
you lubricate the sliders with some white grease (don't get it on the
small wipers or the black caps) the mechanism can now slide more
freely, and the unit can park the head properly without giving you the
dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in
mind that this repair will probably require you to remove the right
panel off of the printer to gain access to the purge mechanism. There
are two screws behind the printer, and two in front for each
corrosponding side panel (the front screws are behind the grey front
panel of the printer - open the top cover to see the clips which hold
the front cover on) Hope this helps some of you out.
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request."
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
mp600 B200, 5010:- examined print head, burnt out = trash
