1993 Mercury Villager Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1993 Mercury Villager - Recently replace battery, Alterator is fine. It starts up good but after running for 15 mins plus it starts to Idle differently and when I take foot off the gas to make turns or stop at lights, it stalls out on me...and is very difficult to start back up again. I've taken it a garage, stated they can't help me unless it's actually doing it at the time. I would appreciate any feed back. Also I noticed when ever I turn the heat up..I start smelling exhaust inside my van...(no ones been able to figure that one out either)
gerry bissi
Level 3:
  • Mercury Master 4,390 Answers
  • Posted on Jan 21, 2011
gerry bissi
Mercury Master
Level 3:
Answers
4390
Questions
Helped
3060605
Points
11499
2answers
94 mercury villager van, passenger auto seat belt motor running continuously & seat belt won't work. Drained battery. Where is the fuse located?
Engine compartment main fuse panel 30 AMP fuse Fuse #4 scroll down and look at this diagram picture on this link. http://www.autogenius.info/mercury-villager-1st-generation-1993-1998-fuse-box-diagram/ caution, this fuse runs power seats, windows and sun roof as well.
Mercury Villager 1st Generation 1993 1998 fuse box diagram Auto Genius
How do i fix my Mercury Villager 2002 with random misfire?
How to Fix error code P0300 for random misfires on your car ...
diy-auto-repair.wonderhowto.com/.../fix-error-code-p0300-for-random-...
Oct 15, 2010 - How to Fix error code P0300 for random misfires on your car ... amisfire (code P0304) on a 1999 Mercury Villager 3.3L · How to Fix error code P0500 ... I reset my codes and it ran fine for a couple of days, then I started getting ...
(code P0305) on a 1999 Mercury Villager 3.3L - auto repair
diy-auto-repair.wonderhowto.com/.../troubleshoot-misfire-code-p0305-1...
Sep 7, 2010 - The vehicle is a '99 Mercury Village, 3.3L, with 150000 miles on it. The chief ... How to Fix error code P0300 for random misfires on your car ...
2000 Villager Misfire - Car Forums and Automotive Chat ...
www.automotiveforums.com > ... > Mercury > Villager
May 24, 2010 - 2000 Villager Misfire Villager Car Forums. ... i was told that the 3.3L engines of 1999-2002 nissan quests/ mercury villagers are INTERFERENCE engines! ... Hope the following may help, and I will post if my last fix works. ... I have a 1999mercury villager that is showing a random multiple cylinder misfire ...
Rough Idle - 2000 Mercury Villager - RepairPal
repairpal.com > Questions > Mercury > Villager > 2000 Mercury Villager
Repair the code issue, because your Villager has OBD-II which is a very helpful Diagnostic system. Upvote (4) ... My 1999 Villager was running poorly; rough idle, lack of power at highway speeds and the engine problem light indicated random miss-fire, etc. I had new spark ... Have code po306 cylinder 6 misfire detected.
P0301 - OBD-II Trouble Code - RepairPal
1helpful
1999 mercury villager jumps time 20 mins after start up won't run till next day
What do you mean by 'jumps time' like engine timing? As in cam sensor? Crank position sensor?
Do you have any trouble codes? If so what are they?
Car stumbles, backfires until warm
You need to replace your distributor. There has been many problems with these. I had the same problem with my 1993 villager and had tried many different things and none worked. I went to a junk yard and got a used distributor and now it runs fine. I would try this before anything alse.
Won't start
have you checked the distributer
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
