Question about Hotpoint First Edition WMA12 Front Load Washer
I bought a Hotpoint firstedition WMA10 washing machine second hand and not sure how to operate it. Is there a manual online
Posted by Josephine Tolland on
Anonymous
    New Friend:
  • 24 Answers
You can download one from hotpoint uk after sales
Posted on Jan 18, 2011
Hi. is the front filter on hotpoint wma10 removeable. The machine is not draining properly after cycle but putting it on spin only cycle twice removes most of the water.
Most hotpoint filters are Located under the drum centre ..you need to remove the big sump hose/ clipe off then the filter is inside here . give it a good clean the water test machine for any leaks before using...Good Luck
Mar 19, 2011 | Washing Machines
Water continues to flow into the detergent box,albeit slowly,until the drum is full to overflowing Model no, WMA10
in the sump hose there is a plastic tube about 6 inches long and it gets blocked.make sure the hose on top of this tube is connected to pswitch in the top.
Sep 14, 2009 | Hotpoint WMA11 Front Load Washer
Hotpoint 1st edtion washing m/c wma10
I think what you need is possibly a new door handle latch or spring, sometimes the spring breaks or becomes weak, it is unlikely to be a fault with the door lock, as they rarely fail.
To replace , undo all screws holding inner and outer door panels together, and prise the 2 panels apart, be careful the door glass does not fall and break
Take note of the position of spring and latch
Please rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 20, 2009 | Hotpoint WMA11 Front Load Washer
Hotpoint WD52 Washer Dryer - no instructions
Hears what to do..
In your browser bar type in hotpoint user manual
Then click on hotpoint user guides in the drop down list
Then input yor model number in the box, and download to your hard drive or to your computer.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Hotpoint WD52 Front Load Washer / Dryer
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition WMA12 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
