SOURCE: On a Designer Style top freezer fridge, what is
the power saver switch is used to activate a low wattage heater in the center rail between the freezer and refrig door to prevent moisture build in hot humid locations. if you live in a dry arid location then using it on pwer saver will save you some money on your power bill. if it sweats between the doors then the switch needs to be set to reduce moisture to prevent mold and mildew build up on the seals and the water dripping on the floor. thanks Peyton
SOURCE: I can't get water to the ice maker. I put on a new
check frost up in freezer check water valve or icemaker
SOURCE: The external metal frame is VERY HOT
Your condenser fan is probably not running. 99 percent of the time that you feel that hot spot it is from the condenser fan not running and the unit is not rejecting any heat
SOURCE: water dripping onto back of shelves and into
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
SOURCE: I have a whirlpool designer style refrigerator
you have to check out for a refrigerator technician to help you out and add gas to it.
