Question about Rokinon 500mm f63 Mirror Lens for Nikon Mount
How to attach filters to a Rokinon 500mm/ 1000mm Mirror Lens for Canon EOS
Posted by mehowardsr on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Rokinon Master
  • 102,366 Answers
For the Rokinon 500mm F/6.3 lens, you can either attach 95mm filters to the front or 34mm filters to the rear of the lens.
For the Rokinon 500mm F/8 lens, you can only attach 30.5mm filters to the rear of the lens.
To attach a filter to the rear of the lens, remove the lens from the camera (or take the rear lens cap off). There's a threaded screw mount just inside of where the lens fits onto the camera. Take your filter and screw it into place. Hand tighten until it's snug and doesn't project in the way---remember, you're going to want to take it off again later.
Posted on Jan 15, 2011
Fungus inside Rokinon F6.3 mirror 500mm lens
This will have to be sent in for repair, no other way around it. Call a camera repair facility first before you send it in to get a quote, many times a new or used lens is cheeper. Don't forget to check Ebay. Good-luck
Error 99 on Canon EOS 350D
Are you trying to waste people's time here, or what?
Rokinon lens, Nikon mount, then mixing that with a Canon EOS 350D???
Installing the Rokinon 500mm/1000mm f/8.0 Mirror Lens for Nikon
This lens does not have the electronics to communicate with the camera. You have to use the camera on the Manual exposure mode (turn the mode dial to M) and set the aperture and shutter speed yourself. You will not get any metering help from the camera's light meter, but you can use the histogram to fine-tune your exposure. You also have to focus the camera manually.
You'll want to use a tripod or other support, as the lens will magnify every bit of camera shake.
2helpful
Rokinon 500mm for nikon D5100
The filters go on the back of the lens (the end that connects to the camera). If you detach the lens and look inside, you'll see a threaded ring. Simply screw the filter on, similar to how you put filters on the front end of other lenses.
Due to the great magnification ratio of this lens, you absolutely need to have it on a tripod or other stable support. Even the slightest camera shake will be magnified.
The lens also has very little depth of field, so you must focus precisely. Since you're mounted on a tripod, you might want to activate the LiveView feature and zoom in the subject while you focus.
How to insert filter in 500mm mirror lens
Look inside the back end of the lens (the end which attaches to the camera). You'll see a threaded ring around the optical part. The filter simply screws onto the threaded ring.
1helpful
1helpful
LOOKING FOR USER MANUAL FOR OPTEKA HD 500MM/1000MM F/8 PRESET TELEPHOTO LENS
GO YO THIS WEB SITE PUT IN MANUALS www.retrevo.com/samples/index.html
3helpful
How do I mount the 500mm mirror lens filter(s) on my new Rokinon lens?
The 30.5mm rear filters fit in the rear of the lens. If you remove the T-mount adapter, you should see the threads which take the filter.
I have 500mm mirror len with canon EOS mount. Can
Maybe you're trying to get it to focus on something too close.
Feb 03, 2010 • Cameras
3helpful
When i attach the rokinon 500mm f8.0 to my sony a-350 i get the following message: "no lens attached. shutter is locked." what do i do?
Set the shutter mode to "M" to control all funtionality of camera. NOTE: The Rokinon 500mm f8.0 don't have control of the f-number but is loked on the lenses, is unique. I hope i'm helpfull. ENJOY your lenses! i have the same!
Rokinon 500mm f63 Mirror Lens for Nikon Mount Logo
Top Rokinon Cameras Experts
Harrie
Tony Parsons
Tony Parsons
Sunrise Camera
Level 1 Expert
Are you a Rokinon Camera Expert? Answer questions, earn points and help others
