GE DVL223EBWW Electric Dryer Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
General Electric DVL223EB1WW Electric dryer no longer heats up. Still blows air, cold, but no heat?? Any suggestion?
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Jan 15, 2011
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10835339
Points
101584
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
The dryer air is no longer hot. Only drys with cold air.
heatman101
Replaced heating element and it still wont fire up
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Ok got a GE DVL223EB1WW Insufficent Heat
Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
6helpful
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Blows only cold air
Check connection to heating elements. My have bad heating elements
2answers
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
