Question about eMachines T6534 PC Desktop
The computer is on but no signal is going to the monitor
Posted by marvinwebb on
Narkus Gimley
    New Friend:
  • 101 Answers
Try taking the monitor into a shop to be repaired, shouldn't cost too much.
Posted on Jan 15, 2011
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
How do i remove the no signal message on the upper left corner of the screen
The reason your getting that message on the screen is because the monitor is not recognizing a video signal from the computer. Make sure your hooking up the monitor to a working computer because then when you go to turn on the computer the message will go away on the monitor.
If you know your computer is working and the message doesnt go away then its an issue with the main board inside of the monitor and since no parts are available for that, you would have to get the monitor replaced.
Sep 30, 2010 | Dell IN1910N 19" Monitor
I start my computer and the monitor says no signal and even after i shut down the computer the screen stays blue and says no signal. any solutions?
Can you try this monitor with another PC or this PC with another monitor? We need to find where you lose your signal at first before going further.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 30, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
Check signal cable
There is no problem. The monitor is telling you that it's not receiving a signal. The reason there is no signal is because your computer is turned off, so it's telling the truth. :D
The monitor should go into idle mode on its own, so you won't see that message for very long. It's annoying, but doesn't cause any real problems. You can save even more energy by shutting off your monitor entirely after you shut down your computer. This will make the message go away and also save money on your electricity bill!
Apr 23, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
I get "No Signal" shortly after the computer is turned.
there is a problem by the programming chip insifde of monitor. It can be faster fixed but only by an expert. If i've help you, please rate me! Thanks
Sep 15, 2009 | Acer AL1916W 19" LCD Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Sep 25, 2008 | Compaq TFT5015 15" LCD Monitor
No Input Signal
Dont Panic it is Nothing...
Your Monitor is safe...
If it say "no Input signal" - "Check VGA cable"
it means that the Monitor is finding signals from the computer,and the cable is either not connected or unsecurely connected.
Jul 18, 2008 | Chi Mei Corporation 221A Monitor
eMachines T6534 PC Desktop Logo
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
