Logitech Cordless Mouse Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant find directions but cant seem to remember how to establish link between mouse and remote
Vinayak Nair
Level 2:
Sergeant:
  • Expert 160 Answers
  • Posted on Jan 15, 2011
 Vinayak Nair
Expert
Level 2:
Sergeant:
Answers
160
Questions
0
Helped
38558
Points
558
Press the connect button on the remote sensor and when it blinks press the connect button under the logitech mouse. The blinking on the receiver should stop if it finds it. Make sure there are not wireless devices like cordless phones, etc beside the receiver or mouse as it degrades the signal.
1helpful
Sharp xg-v10we is password locked
Manual page 64
http://www.myprojectorlamps.com/pdfmanuals/get_manual.php?file_name=SHARP/SHARP%20XG-V10WE.pdf
Clearing the Password
If you forget your password, you can use the following
procedure to clear the password.
(Slide the MOUSE/ADJUSTMENT switch
on the remote control to the ADJ. position.)
MOUSE
ADJ.
ON / ENTER / ON / ENTER / ON / ENTER /
MENU
• This procedure can be performed either from the projector
or with the remote control.
I have the Belkin wireless mouse for my laptop and have lost the directions. I cant seem to get the mouse to work. Can you tell me how to get it to work?
First thing's First: 1. Check Batteries 2. Make sure mouse receiver is plugged into the usb port. 3. Press the button on the receiver and thew button on the mouse to sync them. 4. If they connect then great.
If that solution didn't work try these steps. 1. Visit http://en-us-support.belkin.com/ on the top right of the page search for the model number of you mouse (usually indicated on the bottom of the mouse ie. "Model:xxxxxx"), if the model number isn't on the bottom of the mouse check the receiver. 2. Once you type in the model number to the search box click enter. 3. after you have located the device on the page under the picture it should have a tab highlighted that says "Software, Drivers & Firmware" if this is not selected then select it. 4. Once the tab is open there should be a link for the latest drivers right there. 5. After downloading the driver install it.
I can further assist you if you have trouble if you can locate the model number for me and I will send you a direct link to the file you need.
Hope this helped Please Rate and Comment :)
Cannot link vpn. direct from internet provider works. when try connection via d-link dir625 does not connect. does allow internet access
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Cant seem to find the code for my...
Here you go. Follow this link:
http://www.urc.philips.com/find_baseCode.asp
I hope this solution is helpful. Please remember to rate this solution.
1helpful
2answers
Genius keyboard and mouse kit kb 600:download software
Hi...
I'd go to the Genius website, click on "Service & Support"; "Drivers". In the "Select Product Line" pull-down box, select "Keyboard & Mouse Combination". In the "Select Model" pull-down box, select "KB 600 Black." Scroll down and in the "Select Platform" pull-down menu select your operating system & then click on the "Download" link.
You can also do a Google search with the following search string:
"genius kb 600 driver".
I did and got several hits for drivers for this device, for example:
<http://www.nodevice.com/driver/KB_600_Black/get38762.html>
<http://english.ircfast.com/lv/group/view/kl38237/Driver_Genius_KB_600_Black.htm>
<http://members.driverguide.com/driver/detail.php?driverid=1003001>
Not sure if any of these will work. The first one is 51MB in size; the second is from the UK and is 600KB; the last link is to the DriverGuide website and is 4.6MB in size.
You best bet is to go to the manufacturer's web site & get the driver(s) directly from them.
Hope this helps!
dawog
2answers
Cant get Pointer to move
It's WIRELESS. The receiver is powered by USB. The mouse needs batteries. AAA in most cases! If batteries test ok in a remote control...they should have enough for mouse.
1helpful
2answers
Wireless Mouse
Bud's got it. Remember when pressing the button on the mouse and usb receiver that the mouse has to be brought close to the receiver for them to sync.
1helpful
Labtec optical mouse
Is this a wireless mouse? If so, plug the USB connector into your computer. The pc should detect it and install the drivers automatically. Then there should be a button on the bottom of the mouse, press it, then press the button on the USB connector. This establishes a connection between the mouse and connector.
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
