If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and
Driver
downloads
(if applicable)
as required. The information is normally free of
charge. I hope this helps.
Testimonial: "Thank you I will certainly try this."
of Dealers,
for spare parts and service, and
Installation Instructions
as required.
I hope this helps.
(the following is from http://www.kellerstudio.de/repairfaq/sam/micfaq.htm#mictotdo)
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
If those are not the problems, then the main fuse is the most likely suspect for a totally dead microwave.
Remember, while you can do some repairs on you microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything
inside a microwave. If you want to do more yourself, let me know and I will point you in the direction of some good resources.
